Problem with my eclipse TI
Username: Ccdoggy
Post Number: 138
So recently i brought my Eclipse TI 10", sealed in a 1.43 cuft box, into my home and hooked it into my amp for my home theater. I started listening to it and am hearing something odd, its like it is sounding a little hollow, no its not clipping i dont even have it up that much and my regular sub dosent do this. So i took the sub out of the box and now i can definetly hear the hollow noise more.
Any clue what it could be? too large a box?
Also does anyone know how to remove the motor from it, its a quick change assembly driver. i found a screw but when i remove it nothing happens.
Thanks for the help.
Username: Oglejust
Post Number: 2176
1.43 is a lil on the high side for sealed
Username: Ccdoggy
Post Number: 139
thats what i was kinda sorta thinkin, gunna try fillin the box with somethin to see if it helps.
Any clue on removing the motor? i more or less wanna just see it as it is a pretty beastly driver.
