Silver Member Username: FearthisskyyCarrollton, Texas United states Post Number: 112 Registered: Apr-07 | what frontstage components would ya'll recommend checking out for SQ? diamond audio? cdt? rainbows? exact model would help i heard going 4ohms is better than 2ohm for better SQ is that true? budget is $100-200 for speakers i'm looking at getting the kicker zx350.2 or zx450.2 any other suggestions? |
Silver Member Username: Skibum12189Cleveland Post Number: 727 Registered: Mar-06 | when i get money i'm about to order a zx450.2 and a set of crystal sscs 6's, i've heard this would be a great SQ setup and the comps and amp run about 370 for a 160 dollar set of comps plus a BNIB zx amp off ebay plus shipping all adds to 370 |
Silver Member Username: FearthisskyyCarrollton, Texas United states Post Number: 113 Registered: Apr-07 | oh my bad, i have a 2002 ford explorer and i think those fit only 5.25" comps |
Gold Member Username: DelsolePost Number: 1281 Registered: Feb-05 | then trace and cut so you can fit 6.5's |
Gold Member Username: The_image_dynamicSan Diego Post Number: 1823 Registered: Dec-06 | Diamond Hex |
Silver Member Username: FearthisskyyCarrollton, Texas United states Post Number: 114 Registered: Apr-07 | is that hard to do? i need to figure how to do that out then huh... i've heard a lot about the crystal sscs being good, and for that price i could afford them |
Gold Member Username: The_image_dynamicSan Diego Post Number: 1824 Registered: Dec-06 | Crystals will rock too |
Silver Member Username: FearthisskyyCarrollton, Texas United states Post Number: 118 Registered: Apr-07 | yeah i think i'm going to get diamond audio hex once i get the money again. does 6.5" sound a lot better than the 5.25"? will i get more bass and better SQ or will it be fairly the same if i have a substage since the tweeters are the same i believe. (silk) |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 12428 Registered: Jul-05 | Crystal SSCS's FTMFDVDAW!!! |
Silver Member Username: FearthisskyyCarrollton, Texas United states Post Number: 120 Registered: Apr-07 | how does speaker impedance work? if they say 4ohm can you wire two to 2ohm or 8ohm or would you get an amp that puts out 4ohm? what kind of output would i be looking for for the diamond audio HEX? |
Silver Member Username: Skibum12189Cleveland Post Number: 732 Registered: Mar-06 | i think crystal sscs 5's are 5.25s could be wrong though diamond hex's are awesome too} |
Silver Member Username: FearthisskyyCarrollton, Texas United states Post Number: 134 Registered: Apr-07 | yeah, but I don't know where to get the SSCS-5s from! everywhere on the internet I could only find the SSCS-6. does anyone know where to order a Crystal SSCS-5 from? if not it looks like I'll be going Diamond Audio HEX s500s I am FINALLY getting paid this friday, and plan on buying my components as well as HU this weekend. ![]() |
Silver Member Username: FearthisskyyCarrollton, Texas United states Post Number: 135 Registered: Apr-07 | one more question... will i notice the difference in the 5.25" instead of the 6.5" if there will be subs to cover the lowwws? |
Silver Member Username: FearthisskyyCarrollton, Texas United states Post Number: 136 Registered: Apr-07 | alright would ya'll pick the Rainbow SLC 230 over the Diamond Audio HEX s500s? http://premier-audio.com/index.php?main_page=product_info&cPath=1_2&products_id= 4 the rainbows http://www.woofersetc.com/index.cfm?fuseaction=product.display&product_id=1136 diamond audio |
