Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 185 Registered: Mar-07 | im on a budget so these are gunna be my new speakers. i wont be amping them for a while tho. http://www.diamondaudio.com/content/view/112/125/ i got em for 104 shipped on ebay. should come this friday. does anyone have any suggestion on where to place the tweeter. cause i cant do it in the sail thing cause its blocked off. no kickpod ither. heres a pic of the door: ![]() |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 3122 Registered: Jul-06 | Mount the tweeter using a piece of double siding tape and move it from place to place until you find the spot where you like the sound the best and then mount it at that spot. |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 186 Registered: Mar-07 | sounds like a good idea. the only thing is that theres really not too many places to mount it. i could mount it on the a pillar but then that might screw up the waves or whatever. i was thinking of mounting it right here, where the little yellow spot is, it isnt in the way of anything and its about level with my chest when sitting in the car: |
Gold Member Username: Adam_sPost Number: 1353 Registered: Aug-04 | Some people put them on the A pillar firing into the windshield but like Rob said its a lot about imaging so move them around and see where you like them. |
Gold Member Username: Adam_sPost Number: 1354 Registered: Aug-04 | You just beat me to the A pillar thing. |
