Quick...Wiring question
Username: Volfenhagking1600
SSD Wangin, Shawano, Wis... USA
Post Number: 808
How do you wire a dual 1 ohm sub to 2 ohms...i took my sub out for a while now i cant remember...
Thanks
Jamie
Username: Th3pwn3r
Post Number:...
Post Number: 3087
You wire it in series.You run your positive from your amp to +on coil 1 and then you run the negative from coil 1 to the + on coil 2 and then you run the negative from your amp to the negative on coil 2.Done.
Post Number: 809
Thanks
