The final review
Username: Janitor
Post Number: 16
Ok guys, I've been looking at getting a system for awhile now, and I've picked everything out and will have enough money in a few weeks to buy everything. I want to get this right the first time and have something to stick with for quite awhile. So I want you guys to look at what I've picked out and tell me if I should change ne thing or can find a better deal somewhere. btw this is all goin in the trunk of a 2000 camry.
15" Fi BL (fully loaded) = $354
Kicker ZX1500.1 = $470
FisherCustoms Box = $210
1 Farad Capacitor = $50
0 Gauge Amp wiring kit = $70
_____________________________________
Total = $1154
Los Angeles, CA USA
Post Number: 13373
everything looks good. rather than a cap, why not get a nice battery under the hood. also for that kinda power i would suggest a ho alt.
btw for that power, you would need 2 farad cap rather than 1 farad.
Username: Janitor
Post Number: 17
Alright, what kind of batteries are "nice". I've seen yellow top batteries in people's systems but other than that idk what there called or where to get them, same w/ HO alternator. ne leads?
Los Angeles, CA USA
Post Number: 13374
rather than yellow tops, i'd get a kinetik under the hood. you might be able to fit a kinetic hc2000 under there. if not then the hc1800 will definately fit under there. still look into a ho alt man. 1500wrms is alot for the stock alt. not to mention the kicker amps are underrated.
Username: Janitor
Post Number: 18
alright thanx alot man. so HO alt + kinetic bat > 2 F cap. that may set me back a week or so, whats a good price for a hc2000? I'm lookin @ one on eBay for 250ish shipped.
Los Angeles, CA USA
Post Number: 13375
no capacitor. just a good batt and a ho alt is fine.
also that price is about right. unless you live in southercal then i can find you a dealer that sells them for $195.
Username: Janitor
Post Number: 19
and by HO alternator you mean http://www.highoutputalternator.com/index.htm right?
Los Angeles, CA USA
Post Number: 13377
yeah. you can also ask iraggi alternators. look for it on ebay. if you don't find one for your car on there, then email him for a quote.
Username: Ctmike
Ct.
Post Number: 4628
http://stores.ebay.com/Iraggi-Alternator-and-Electronics
Username: Janitor
Post Number: 20
alright thanx alot man! really helped =D
Username: Nd4spd18
Southeast PA
Post Number: 2991
Lose the capacitor and put the money toward the HO alternator
Username: 420alldaylong
Post Number: 1892
Sundown SAZ-1500D $450 at Low Hz.com give Kevin a email. lowhz01@yahoo.com
