Conversion?
Username: M0nkeyman692
Post Number: 232
how do i make a car sub amp work in a house..
i was wondering if this would work temporarily but i would rather have a better way.
i take one of those quick chargers for a car that you plug into an outlet.. and then hook up a battery to the charger. and then hook the amp to the battery and the sub to the amp...? and somehow hook up controls and stuff to that so i can play music on it. will that work
A pic is worth 1000 posts!!
Post Number: 7170
Using a lead acid battery indoors is dumb/dangerous. I wouldn't.
Post Number: 233
yea makes sense... what do you think i should do
Username: Wolf_hound
Post Number: 235
lol i did that in my house but it was with a sealed battery but the most you can have is like 300 watts. i connected a 400 watt amp and i could only turn it up a little bit because it would cut off. Then i connected a 200 watt and i could turn it up all the way but it wasnt loud enough for me i just connected it to my home stereo and it bangs harder.
Post Number: 234
yea i have a 500rms house sub right now and it bumps nice
but i have an aw1206t in a 2.2cuft box and its tuned to like 30 or so. so its low and i wanted to use it for movies and home audio and stuff
so no ideas for any way to make it happen
Username: Nd4spd18
Southeast PA
Post Number: 3005
This has been discussed about one zillion times before. It ain't practical.
Username: Cenus
Hicksville, Ohio
Post Number: 3251
you need an ac to dc converter which is useally very exspensive, i'd just buy a surrond sound then change to speaks to your liking.
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 1341
just buy a plate amp or external AC amp they are much cheaper then AC-DC converter.
Username: Snarl2004
Post Number: 1342
http://www.partsexpress.com/webpage.cfm?WebPage_ID=219
Username: Snarl2004
Post Number: 1343
Username: Snarl2004
Post Number: 1345
sry for the double post
Post Number: 7206
If you wanna use car subs at home do what I did.
https://www.ecoustics.com/electronics/forum/off-topic/340368.html
Username: Snarl2004
Post Number: 1351
fu<king show off.lol. but i never get tired of looking at that great work u did
Username: Moey_g
SydneyAustralia
Post Number: 98
Use a computer power supply. Works for me and it has been for about 6 months now. Im only running a small boss amp on a 12" pioneer, but it is working. I dont know if you could use this idea for a bigger amp tho.
Post Number: 7213
Sorry Snarl, I always get slack about how ghetto it is to use car subs in a HT setup. When done right it kicks royal azz. The uptight home audio guys always frown on it. It works for me.
Post Number: 235
how do i get that amp and how much does it cost and how many rms is it
Post Number: 7216
http://www.partsexpress.com/pe/pshowdetl.cfm?PartNumber=300-808&AID=1457539&PID= 440939&rak=300-808&raid=44
Worth it. IMO.
Post Number: 236
400's not too bad. ill definitly think about getting one of those
Post Number: 237
how would you wire a q to 4 ohm
Username: Th3pwn3r
Post Number:...
Post Number: 2982
It would have to be either a dual 8ohm or a dual 2ohm to be wired to 4 ohms.
Post Number: 239
oh ok
