Subs?
Username: Pbplayer05
Post Number: 35
was thinking bout getting 2 12' rockford p3 or p2 or maybe a pair of type r's which would sound better and be louder i was thinking bout using a kicher zx 750.1 or a kx 1200.1 or maybe a zx 1000.1 or a autoteck mm1400 are these good
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12383
why where you thinking about these subs??
Username: Ctmike
Ct.
Post Number: 4574
type r's. but what is your budget? you can get better and wont have the same thing as everyone else in half the world.
Username: Jblanford
Post Number: 1254
because he went to a local shop and got brainwashed by all the mainstream brands
Username: Mygame5982
I Got Serious Wang H-..., TEXAS US
Post Number: 1792
type rs kicc assssss man
Username: Ctmike
Ct.
Post Number: 4576
don't get the r's!! get something else, anything else.
Post Number: 36
got any suggestons for that price range then
Username: Jblanford
Post Number: 1256
whats your budget ?
Username: Ctmike
Ct.
Post Number: 4577
well what were you going to pay for them? and to let you know, when looking at subs, take into consideration the power you'll have to run and the possible charging system upgrade.
Post Number: 37
for the subs around 200-250
Username: Jblanford
Post Number: 1257
are you stuck on 2 12"s ? could you settle with 1 12" or 1 15"
Post Number: 38
around 200 for a pair of any of them and a little less for the p2 ya i know that my power system should beable to take about 1000 watts which makes these subs a decent setup but if theres something better for the price help me out
Post Number: 39
depends if it will be louder than the system i have now which hits a little over 130db right now
Post Number: 40
any suggestions would be appreciated
Username: Jblanford
Post Number: 1260
like i asked...
"are you stuck on 2 12"s ? could you settle with 1 12" or 1 15"?
Username: Ctmike
Ct.
Post Number: 4579
what kind of charging system you have now (size of alt.)? and what is your system now and what kind of meter was used when you hit that #?
Post Number: 41
i would prefer two 12 but if one 12 or 15 could hit better i would go that way
Post Number: 42
105 amp alternator
Username: Jblanford
Post Number: 1263
if you have 1000rms to work with i would look at Fi Q or BL 12"
Username: Jblanford
Post Number: 1264
and thats based on the budget you gave me
Username: Ctmike
Ct.
Post Number: 4580
if that's your budget and you just want to hit louder than your subs now (which you still haven't posted) go ahead and get a pair of cvr's, 2 for $149 shipped and you can run them off the zx1000.1. more spl than any sub you mentioned at the beginning.
or save more <--personally what i'd do.
Post Number: 43
ct mike if i would save up what would u recommend and how much would i needwell does anyone have anyother suggestions on subs and were do i find the fiq and the dl at might possibly buy 2 12' rd audo classis from kevin otherwise but would stll like the input
Username: Jblanford
Post Number: 1265
buy the classics man
Username: Ctmike
Ct.
Post Number: 4582
www.ficaraudio.com, have to buy direct. and for what to buy, really depends on how much you save, and available power.
Post Number: 44
ya im still thinking on it but were is the fi q or hat bl at idk wre to look
Username: Jblanford
Post Number: 1267
Fi has a website ??? wow !
Post Number: 45
well ikevin just told me about the cadence fx subs anybody heard them before
Post Number: 46
Username: Jblanford
Post Number: 1270
it doesn't seem like you're going to have to much power to work with
If you have like 600-1000 rms go with the FI ssd- https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154663af7c9813d/shopdata/0030_SSD/product_overview.shopscript
if you have 1000-1400 go with the FI q or bl- https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154663af7c9813d/shopdata/0020_Q/product_overview.shopscript
https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154663af7c9813d/shopdata/0015_BL/product_overview.shopscript
and no im not a Fi fan boy, but its hard to beat the performance for the price
