(4) DD 1010 SPL Box
Username: Night_mirage
Amman, Jordan DDs dealer i...
Post Number: 644
I want to build a ported box for
(4) DD 1010
I'm powering them by pair of kx2500.1
What dimensions ?? PLZ HELP //
Username: Zacdavis
Beloit, Wi
Post Number: 547
You going to run a 2 subs to each amp (2ohm mono?)
Those amps arent strappable.
Also, that is way to much power for those subs, i'd hate to see you fry'em.
I wouldnt recommend more than 500rms each, and that would be for a mature listener.
Are you just going to be burping these with this power? If so I'm curious to see how they hold up, I'm sure they'll fair well mechanically, thermally however it'll be close.
Excited to hear your results.
As for a box size?, what car are you looking to build for, will you be looking to do a number on the dash or in the kick?
Username: Th3pwn3r
Post Number:...
Post Number: 2776
If you're going to run that kind of power you better be sure to have a serious charging system to support all the current draw.
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1729
an SPL box is alot of guess and check. dont expect to make 1 box and it be perfect.
Username: Logan__tille
Team Revolution
Post Number: 7508
You are the only one that knows the dimensions you need.
Username: Nd4spd18
Southeast PA
Post Number: 2647
X2 to Rob's post
You better have a massive electrical system if you expect to run two KX 2500.1s.
And yeah that is way more power than those subs take.
Username: Cenus
Hicksville, Ohio
Post Number: 3198
x2 to zac's post, thats way to much power for those, i'd go with the 1500 serires if your gonna run that much power, as for a box we need to know the dimensions of your vehicle we can't just guess in the dark, but my guesstimate would be around 8-10cf tuned to 40hz. you better have a chargin system to like what rob said, those 2500.1 put out close to 3000wrms each so you'll be running around 6000wrms that equals a huge alt and a bunch of batterys to feed those beasts.
Post Number: 645
I heard 1000 series can take over 1000w ,And the car is Mitsubishi Bajiro .
I'm thinking about 7cuft
I do have a big space So don't worry about Space .
I have 300A HO ALT , 4x 2400 KK Battery .
I think thats Enough > What do u think ?
Its my first time to do SPL box , And 4sub's
So i don't know what to do ?
We will have the first competition in our Country and i'm the only one who is going 2 use DD . They Does n't know anything about Digital Design .. They just know about Pioneer , JBL , Kicker , Sony (bla bla) , Kenwood ..
So i wanna Show them WHATS THE REAL DD .
Any idea will be welcomed .
I'm the DD dealer in JORDAN .
And i can use 9500 series , But i want to be simple by 4x 1010 ..
Username: Th3pwn3r
Post Number:...
Post Number: 2781
Well you should be fine running those amps off of that charging system :-) Go with DD 3510s,they should be fine with handling that kind of power.Oh and although you have 4 batts and a 300 amp alternator be sure to watch your voltage level after several burps.
Post Number: 646
ok thanks Rob . But i wanna still useing 1000 series and 10's ..
To tell ppl thats our normal sub . And we have 2500 , 3500 , 9500 > That would be better ..
Ok Guys . Do u prefer Doing 4x 1010 & Z1 ??
I think if its all DD would be better ??
Username: Th3pwn3r
Post Number:...
Post Number: 2783
If you're planning on running the 1000 series just make sure to test some back up subs so that way you can see the limits of the woofer.If you go to a show and you blow up your subs people will see that and it will actually steer them away IMO from the subs,even if you are clearly over-powering them,especially if you're trying to impress everyone.
Username: Zacdavis
Beloit, Wi
Post Number: 551
For a DD dealer I would think you'd know there is no such model as 1000.
The 1000 series was replaced by the 1500 series.
While they share the same soft parts, the motor is now double stacked with a flat backplate instead of the single stack with extended bump plate.
Again, they handle the same power.
In addition, those subs won't even hold a single burp with that kind of power.
Take Rob's advice, GO WITH 3500's!!!!!!! :D
Post Number: 648
I know that , But i still have 1000series , Don't Worry
About that kind of power i installed pair of 1015's on kx2500.1 for a Demo car and it sounds GREAT . Don't underestimate this series ..
and i know it can hold , But if i would replace them , I would Do 2510's .
Thanx All of u ..
I just want advices for an SPL box , Cuz its my First SPL ..
I do have that Dimension
70' Width
120" Depth
150" height
Post Number: 649
ops . I lost in Converting between mm and Inch
So thats it
50" W
60" D
50" H
Username: Adddisorder
West palm, Florida
Post Number: 4429
i would just do the 2510 and a z1 it should be very impressive. or do 2 z1s and 4 3510's.
iv heard the 1000s will take 1k too but why not be on the safe side.
whatever size you decide to go with i would make a few boxes tuned like 40-45hz and see whats loudest in your car.
Username: Zacdavis
Beloit, Wi
Post Number: 552
If you need anymore I've got 8 1010's in stock.
Post Number: 650
i'm in Jordan Honey (Not In USA)
So i can't take just 8
I'm an international Dealer ..
he he ..
Thanks anyway
West palm, Florida
Post Number: 4435
^^that is a wall of sexy!
