HO Alternator for Kicker ZX1000.1?
Username: Fearthisskyy
Carrollton, Texas United states
Post Number: 54
I have a 2002 Ford Explorer that comes with a 130 amp stock alternator... is that enough to run the Kicker ZX1000.1 or should I get the ZX750.1 instead?
If the zx1000.1 fits I plan on getting the Fi Q15, if the zx750.1 fits, I plan on getting the Fi SSD15... is there a big difference in SQ and SPL between the two?
Username: Hgihkcin
Lincoln, NE
Post Number: 181
you should be fine with the 1000.1 and the Q, unless you are running a ridiculous speaker amp.
Username: J_c_wheeler8
Columbus, IN United States
Post Number: 623
I'm running 2 Type R's and a kx1200.1 on stock 110A alternator. Its kinda pushin it, but with 130A on a ZX1000.1 you're golden. Stick with the Q and let me know how you like it, im looking into gettin a Q possibly down the road.
Username: Extrmndor3
IF U HEAR ME... crazydbs.com
Post Number: 5023
my explorer got the 120 and ummm imrunning over 2000 rms :-)
Username: Sheriff
Post Number: 399
Ya, you should be fine. If there is any voltage drop when you get it, which I doubt, just do the Big 3 and you should be set.
Username: Basssquared
Kansas
Post Number: 429
yeah rob can you explain to me again how you do that didn't you say that you just did the big 3 and you were set or what else did you do?
Username: Logan__tille
Team RD Audio
Post Number: 7419
my tracker got the 55a alt and im running 2500rms
Post Number: 635
LMFAO
Username: Jkidder
Spring hill, Florida Usa
Post Number: 625
they make 55amp alts? lol
Username: Matt12490
California USA
Post Number: 2404
Only for pieces of sh1t
Username: Charlesbhs
Post Number: 38
i think my car has a 180-alternater. is that good? how big of an amp could i get with that?
Username: Jkidder
Post Number: 654
wat kind of car sweeney? do big 3 and an extra battery u could have about 1.8-2k on that safely id guess.
Post Number: 44
2007 bmw 328i
