Need crystal clear speakers
Username: Sheriff
Post Number: 396
I'm looking to get some new speakers so I can hear the words to songs well over my spl sub. I currently have all Pioneer speakers, but they just aren't cutting it. What do you guys recommend to fit my needs.
Username: Quig
PgH, PA US
Post Number: 561
if ur running them off ur HU then there not geting enof power, put an amp on them
Username: Sheriff
Post Number: 398
Would that make them more clear? If so what amp should I get, I'm not sure of the model of the speakers because they were in my truck when I bought it.
Username: Nd4spd18
Southeast PA
Post Number: 2569
CDT, Focal, and JL all make good components. Make sure you also get a good amp for them though.
Username: Sheriff
Post Number: 402
I thought comps were for bass? I'm just looking for something where I will be able to hear the words over my sub. If I run an amp on my current speakers will it work?
Username: Tremor1127
Fi Car Audio has got m...
Post Number: 1548
no, componenets are the 6.5 + seperate tweeters + crossovers.
adding an amp to your speakers should make them louder and clearer but chances are the pioneer coaxials you have suck.
i would get a nice component set and cheap amp for them.
you can get a decent component set and amp for them for under 200 but a budget of up to 400 would give you alot of nice options.
Username: Sheriff
Post Number: 403
I will probably do that then.
Username: Sheriff
Post Number: 404
How do these look?
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4418
Username: The_image_dynamic
San Diego
Post Number: 1431
Diamond Hex Silks are still among the best I have heard/installed/owned and IMO fairly close to similarly priced models from Dynaudio, Focal, CDT, Morel, Rainbow, JL, etc. I love the sound and impact of the Hex's and I am not quite sure why some people around here don't recommend them.
Username: Jkidder
Spring hill, Florida Usa
Post Number: 645
by speakers do u mean subwoofers? cuz thats wat section this is!
San Diego
Post Number: 1433
He probably posted it here since there isn't much traffic in the Speakers section.
Username: Jkidder
Post Number: 646
true but theres more traffic here because more stupid questions get asked here. i go to the speaker section just as much as i do subwoofer.
Post Number: 1550
corey, those CDTs in the link would be nice.
Username: Sheriff
Post Number: 405
Alright I will look into getting a pair of them. What do you think I should use for an amp for them? Also, should I just get 1 pair of them or 2?
Username: Sheriff
Post Number: 406
Didn't bump.
