Gold Member Username: Thomas_gNM Post Number: 2333 Registered: Oct-05 | Ok like i said im going with 8 12" pioneer premiers. I need to get all 8 down to a 2 ohm load bridged, or in stereo on my amp on each channel a 1 ohm load. i was thinking getting them all dual 2 ohm then series wire each sub for 4 ohm then parallel 4 subs to be 1 ohm load right? Then the same to the other four is this correct? Thanx. | |
Silver Member Username: Jesse59672OK Post Number: 336 Registered: Feb-07 | you lost me. but 8 12's badass. i have one 12 and i'm going for 146-147db | |
Gold Member Username: Thomas_gNM Post Number: 2334 Registered: Oct-05 | Wired like this. Yeah i hope to hit over 150 db with this setup at the comp.
Gold Member Username: Thomas_gNM Post Number: 2335 Registered: Oct-05 | Grrrrrr damn pic came out too small!!!! | |
Silver Member Username: Joebruce15 Inch Wang... Post Number: 889 Registered: May-04 | You can do it like this for 4 dual 2 ohm subs to get 1 ohm to each channel http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=4&woofer_imp=3 |
Silver Member Username: BudlingCali USofA Post Number: 340 Registered: May-06 | Use pic one for 2 channel 1ohm ![]() Use pic two for bridged 2ohm(take the two sets of four and wire down to 2ohm. ![]() |
Silver Member Username: Joebruce15 Inch Wang... Post Number: 890 Registered: May-04 | ^^haha beat you to it! ![]() |
Gold Member Username: Thomas_gNM Post Number: 2336 Registered: Oct-05 | alright so then i was right, thanx alot man. | |
Gold Member Username: Thomas_gNM Post Number: 2337 Registered: Oct-05 | whoa two more posts while i was typeing(im slow) thanx alot guys. | |
Gold Member Username: JohnfiacA-ToWn, Kingkong ain... I got Chuck ... Post Number: 2841 Registered: Mar-06 | get 10K on them ![]() |
