Silver Member Username: Jesse59672OK Post Number: 280 Registered: Feb-07 | i need some info on this sub. it isn't listed on pioneer's website ie the xmax, driver displacement anything else you may have. and if anyone has or has had this sub what did ya tune the box to. how many cuft per sub? |
Silver Member Username: TurnmatPost Number: 173 Registered: Feb-07 | xmax: 11.2 mm displacement:.084 you have to look under the older subs to find the info and than you need to look at the manual |
Silver Member Username: Jesse59672OK Post Number: 281 Registered: Feb-07 | so its really that low? i got .43 inches or 10.92mm from another forum and wasn't sure if it was right or not |
Silver Member Username: TurnmatPost Number: 176 Registered: Feb-07 | yea its that low... here is the link i am not sure if it will work though http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/217888139TRD126 3-A_UC.pdf |
Platinum Member Username: RovinMy 1 12 Atom... Post Number: 11446 Registered: Jul-05 | i had mine in a few boxes but it seemed to like 2.75cuft-3cuft 33-34hz - i even heard some ppl put it in up to a 4cuft box but i wont advise u to do that evrey1 seems to think its a spl sub when in fact after its fully broken in sounds quite musical & u get the looows real good too - in fact after only 1 wk of break in it actually shook the rear hatch lock off in my ride ! u can use of the ol basic rule of @ least 12sq"\cuft to give some nice SQL bass .... |
Silver Member Username: Jesse59672OK Post Number: 283 Registered: Feb-07 | oh good find. i couldnt find my owners manual |
Silver Member Username: Jesse59672OK Post Number: 285 Registered: Feb-07 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=38.5&Eh=12&Dia=6&Xmax=11.2 &Vd=.084&NumW=1&Vb=3.1&Fb=32&Qts=&Vas=&Fs=&CE=0 heres my box i'm planning.. tuned @ 32hz |
Silver Member Username: Jesse59672OK Post Number: 286 Registered: Feb-07 | BUMP |
Silver Member Username: Jesse59672OK Post Number: 287 Registered: Feb-07 | stupid @$$ forum wont bump lol. |
Platinum Member Username: RovinMy 1 12 Atom... Post Number: 11447 Registered: Jul-05 | i still have plans from what i used & i think its this http://www.subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=15.5&Dia=6&Xmax=10.9 &Vd=.084&NumW=1&Vb=3&Fb=33&Qts=&Vas=&Fs=&CE=0 ... |
Silver Member Username: Jesse59672OK Post Number: 293 Registered: Feb-07 | nearly the same box, yours is just fatter mine is skinnier ill probably make it on wednesday-thursday so ill post pics after i'm done |
Silver Member Username: PaogrAthensGreece Post Number: 127 Registered: Dec-05 | Hey jesse in your plan you have put only 12" for height. I think you have to put a little bigger number... |
Platinum Member Username: RovinMy 1 12 Atom... Post Number: 11450 Registered: Jul-05 | trick i used Jesse was to design mine in such a way that u get the port with the least "L" shape bend (only 1\2" in mine) leading to easier air flow & least resistance ....![]() |
