BOX CAME***
Username: Volfenhagking1600
15 SSD Wangin, Shawano, Wis... USA
Post Number: 699
Gotta go hook it up...FINALLY
Los Angeles, CA USA
Post Number: 12614
congrats man. who made that box? it looks clean.
please bump responsively.
chad
Username: Rovin
My 1 12 Atom...
Post Number: 11441
looks good - i bet logan prolly made it ....
Post Number: 700
logan made it...i have a question. When setting my gain i need a 50 hz test tone right? My dustcap got kinda warm when i was setting it is this normal???
Post Number: 701
and when i set my gain with the test tone its real loud...but when i test it with a cd w/ music its weak as hell... Help please
Los Angeles, CA USA
Post Number: 12625
you are suppose to disconnect the sub when setting the gain. just disconnect one cable so no sound comes from it.
Post Number: 702
yea but it is real weak when i play music
Username: Mrskullz1
Brooklyn, New York
Post Number: 369
whts ur subwoofer level at? its all the way up right?
Los Angeles, CA USA
Post Number: 12626
wait are you setting it with the dmm? if not then follow this instruction.....
Tweaking Your Bass
By AdireRulesForever
Here is a tweaking process for getting the most from your subs and amp. Additional boom from the sub(s) is/are our main goal here, so will focus mainly upon that. Here we go:
Get out a few of your favorite CD's. Something with good mix and some low thump content. Dial back on the sub amp gain so there is very little sub in the mix. Turn off any bass boost features in the amp for now. May need a little later, but for now, no bass boost for now. Let's get to work 'cause BABY, it's cold outside!
Set the EQ functions on HU to "0" or "flat" (no cuts, no boost)
Pop in the CD/tape/MP3 and select your favorite cut(s) and repeat.
Turn up the HU volume knob until you hear some distortions from the interior stage speakers.
Back off on the volume until distortions are gone. Is best to get out of the car and listen with doors open from a few feet away. If you still hear a rough sound, back off on the volume a bit more.
Now, time to add the sub into the mix. If amp has a low Pass filter, set it in a range between 70-120 Hz. No bass boost just yet. If you have continuously variable LPF, determine what sounds best in your ears, within the range noted.
Bring up the gain on the sub amp, until you get it thumping and hear a "little" distortion.
Back off on the sub gain (a wee bit) until it sound full, deep and clean.
If bass seems a bit lacking of punch or deep lows, a small amount of Bass Boost, can be added. (+3 to +6dB is all you should ever need here)
Again, if you hear the sub getting rough from distortion, back off on the gain a bit more.
Now, you may use the Bass Tone control on the HU to adjust your bass from the driver's seat. This works well in simple HU's. But if you have a menu driven EQ system, this is a bit more cumbersome.
That's about it and now time for a test drive to ensure you have the system well balanced and in control. However, if you still have poor bass performance or weak bass output. May try reverse the wires to the sub and see if that improves the overall affect. If it gets better, you're good to go. If it seems worse, return the sub wires to original orientation.
Finally, if you have done all these steps correctly, and the bass is still not getting much bump or louder, and your gains are maxed out, you may have to go back to the LOC's and adjust them, in conjunction with the sub amp gains.
The LOC's trim pots, act like water mixing valves. Turing them in one direction, will feed more input voltage to the sub amp. Going the other direction on the pots, will reduce your sub output power. This optimizing process, should get your sub(s) up to par with the rest of your system. If not, something is off kilter here and needs more attention. Happy thumping!
Post Number: 703
yea its all the way up skullz
Post Number: 704
i dk why it would be so so much louder
bump
Username: Matt12490
California USA
Post Number: 2342
Thats what test tones do.
edit:Which is why competitors use them for maximum SPL.
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 7205
NICE!!! Hope you like it:-)
Post Number: 705
I figured out that my subsonic filter was on...I turned it off and it wanged hard as h311
Username: Dakangofkrunk16
Post Number: 67
Is the subsonic filter a nob, i thought it was, and your suppose to adjust it accordingly
if you box is tuned to 32 hz, then u tune it to 32 hz or 33, not entirely sure
It is so ur subs dont go below tuning level, which could be bad, i think
Username: Joebruce
15 Inch Wang...
Post Number: 805
Yea you need your ssf on if you have a ported box. Set it a lil under what your box is tuned to.
Post Number: 7212
Bump for a nice a$s box!!!
Post Number: 706
well according to a local deuschbag in town..."
i should get a better box" lol...and i should of got a W7.
Username: 420alldaylong
Post Number: 1675
Fock mainstream what you got is the sh!t.
How many cubes and what is it tuned at.
Nice box Logan.
Post Number: 707
3.5 cubes @33hz
Post Number: 708
the guys like i know someone thats louder. I was like Ok...lol I asked him what he had and he said a W7 for $300, and a memphis m class 2000 watt amp...i asked him if he had any electrical upgrades. and he said yea a 4 farad cap.LOL
