Silver Member Username: Jesse59672OK Post Number: 261 Registered: Feb-07 | alrighty then first off i need some links and stuff about box / port planning my box isn't hitting the lows like i want it to so i'm thinking of just building another box. it hits highest at around 38-39 hz.. i want it lower.. was thinking about tuning it 32hz never built a box before. heres my plan: L: 38.5, W: 15, H: 12 i guess all i'm asking is how to go about making this what sh!t will i need. also how many cuft is this box? |
Silver Member Username: Jesse59672OK Post Number: 262 Registered: Feb-07 | ah 4.1 cuft is that right? |
Silver Member Username: Jesse59672OK Post Number: 263 Registered: Feb-07 | come on lol what would you guys tune it to? should have i have the port / sub firing up at the glass? (i have a hatchback camaro) |
Silver Member Username: Solobaric4lifePost Number: 778 Registered: Jan-07 | 3.035, is your total cubic ft, not counting the ort |
Silver Member Username: Jesse59672OK Post Number: 264 Registered: Feb-07 | i still don't know the xmax.. or what it is.. it isnt listed on pioneers website i have a TS-W3004SPL pioneer premier. like the picture above, that is the amount of room i have to work with, and i prefer the port / sub facing up. thanks for any of your help |
Silver Member Username: Jesse59672OK Post Number: 265 Registered: Feb-07 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=38.5&Eh=12&Dia=6&Xmax=10.9 22&Vd=.084&NumW=1&Vb=3.1&Fb=32&Qts=&Vas=&Fs=&CE=0 is what i came up with.. i got the xmax and sub displacement from here http://forum.carstereos.org/ts-w3004spl-t61214.html?s=e97076321d943692277a35016f 609e35& i dunno if either are accurate but that box looks about right.. what do you guys think |
Bronze Member Username: Mwyant19Arlington, Texas Usa Post Number: 88 Registered: Mar-07 | no clue, never built a box before. there are people on here that know all about this stuff tho... just bump this thread for a day or 2 and you should get some solid advice. you should post exactly what kind of equipment (sub amp etc.) you plan on using. |
Silver Member Username: Jesse59672OK Post Number: 266 Registered: Feb-07 | meh that should be plenty of info lol.. 1160rms |
Silver Member Username: Jesse59672OK Post Number: 270 Registered: Feb-07 | bump before work! |
Silver Member Username: Jesse59672OK Post Number: 271 Registered: Feb-07 | lol anyone? |
Silver Member Username: Jesse59672OK Post Number: 274 Registered: Feb-07 | i'll be on aim if anyone can help me understand some sh!t jesse59672 |
Platinum Member Username: BestmankindLos Angeles, CA USA Post Number: 12647 Registered: Oct-05 | got a question jessie. have you heard your sub hit low or is that the first box you put it in? the pioneer subs are known for getting loud at higher frequencies. they don't get low at all. i had that sub in a sealed box and still didn't hit the low. |
Silver Member Username: Jesse59672OK Post Number: 278 Registered: Feb-07 | i haven't heard it hit really low, i just know that 30hz sounds like crap with subsonic filter down. you got aim chad? |
