Best SQ 5.25" Component Speakers
Username: Fearthisskyy
Carrollton, Texas United states
Post Number: 25
Best 5.25" Component Speakers suggestions
Budget is preferably $150-200.
$250 if there are components out there that are SIGNIFICANTLY better compared to ones in the budget.
a few I've been looking at: Focal 130 A1, Infinity Perfect 5.1, Eclipse SC8254
Username: Treez
Post Number: 14
Really clean, sounding set of components. will sound great even with 50 watts rms. They lacking a bit in the midbass, but crisp highs. overall .. a great listening experience..
Be sure to check the available space for mounting.
Username: Dlavante
Tigard, Or USA
Post Number: 63
i personally like mb quart Q components but some people say theyre a little harsh
http://www.millionbuy.com/mbqqsc213.html
they sound really good on 75-100 watts
Post Number: 30
Sean, which one are you talking about??
that'd be tight if I got the MB Quart Q bc I'd have the Fi Q and MB Quart Q in there
Username: Alteraudiousa
Concord
Post Number: 1531
^^^^thats a silly reason to get a set of speakers. Rainbow, maybe CDT but CL-e series is about the only thin close to that price range, HD would be much better but more expensive.
Username: Warlok
Orlando, FL USA
Post Number: 277
I agree with AA. Diamond (HEX)also has some pretty nice comps in that price range. they sound very clean.
