Finally ordered a battery.
Username: Southernrebel
Post Number: 4913
Well, i have been runnin off a stock batt and a 180A alt for a LONG time....but i just ordered a Deka Intimidator.
I have been doing high 149's w/ my voltage dropping to ~9.6v :-)
Wonder what i will do w/ this D31 about 2ft from my amp? ***humm***
This should be fun.
Username: Solobaric4life
Post Number: 702
hell yea lol, what amp pushin it?, its a 9515 right?
Username: Mwyant19
Arlington, Texas Usa
Post Number: 70
man i have a hyundai elantra with a 1000wrms amp and 1000w sub and im having voltage drops like a mofo. my sub stops hitting after a while when the amp shuts off. i think i need a new alt+batt+big three but its hard as hell to find alts for my car. 2005 hyunda elantra. let me know if u guys have sources or info
Username: Mwyant19
Post Number: 71
all i can find is these crappy stock 90 amp. i believe i need more like 180 amp
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 2267
yeah and you're clipping your sh!t to death mwyant...
Anyways, awesome Canaan. 150 should be easy now!
Username: Waterboy2289
Georgia, DiRtY SoUtH ... 2 18 SX w/ ...
Post Number: 345
Hell yea!!! I have that battery! It has treated me very well. You can't beat it for the money.
Username: Th3pwn3r
Post Number:...
Post Number: 2390
"I have been doing high 149's w/ my voltage dropping to ~9.6v
Wonder what i will do w/ this D31 about 2ft from my amp? ***humm***"
All I can say is LOL.
Username: Th3pwn3r
Post Number:...
Post Number: 2391
"I have been doing high 149's w/ my voltage dropping to ~9.6v"
That's legal right?
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 1113
Hmm I think you might get louder.
Los Angeles, CA USA
Post Number: 12573
congrats on the new battery. go out there and break that 150 mark and join me in the 150s club. lol.
Username: Mike11202
DE US
Post Number: 469
Isnt that bad going to 9.6v?
I usually make sure mine doesn't go below 12.0
Username: Th3pwn3r
Post Number:...
Post Number: 2396
"Isnt that bad going to 9.6v?
I usually make sure mine doesn't go below 12.0"
Dropping below 12 volts is never good.It CAN cause your amplifier to clip.
Username: Adddisorder
West palm, Florida
Post Number: 4218
but his amp can run on lower voltages so its probly ok down to 9-10v
Username: Th3pwn3r
Post Number:...
Post Number: 2400
Mat you're correct but the less voltage your amp has to take in, the less voltage it produces,you can't get something for nothing. :-)
Username: Clouduz
Post Number: 190
i thought you kill your battery slowly if you drop below 11v
Post Number: 725
^^^ i killed mine like that, i got a new cheap azz 1000 amp everlast now, but it has free 3 yr warranty-ftw
Post Number: 4915
Ok guys...I don't consistantly drop to <10v, its just when I burp.
I stay well over 12v when I drive, I listen to my bass at a "reasonable" level *wink-wink*.
I should have the batt by mid-late next week.
Username: Johnfiac
A-ToWn, 152-153db Da... My wangers b...
Post Number: 2648
Some amps can take low voltage and extra voltage no problem, most of those amps are made specifically for competitions tho.. but are used in some daily setups as well but typically you dont want do drop under 12.5V if your car is running expeccialy, not only for the fact of your amps safty but also for your cars electrical system.. and draining your battery under its floater voltage alot also causes the life of the battery to decrease alot faster like a optima yellow top i heard the avg. life of it is upto 100drains\recharges and its basically dead. But as long as you dont drop the voltage below the floater alot or by much you ussualy wont have a issue. Hopfully with this new battery you should stay 12.5+ should dish out a lil extra power for you ;)
Post Number: 4917
exactly.
