Wal Mart amp kits
Username: Wolfman1966
Dont forget to check m...USA
Post Number: 2565
Are the Schoche ones any good, or they do have one Monster Cable kit that says its good for up to 500 watts..The Monster one is about $40, the Schoche is about $30
Username: 420alldaylong
Post Number: 1437
Waste of money
Post Number: 2566
both??
Username: Oglejust
Post Number: 1432
monster cable>schoche
Username: Carguy
Post Number: 6131
Wires are made almost the same way. Look at the number of strands.
You can pay $150 or $40 and it'll sound the same. Don't get fooled by sneaky marketing ad.
Username: Gh0st_31
FL USA
Post Number: 390
i dont think the schoche wire is that bad. i was pushing a directed 1100 on a 4 gauge 600 watt rms wire kit, and it melted the fuse holder but worked the whole time lol ( back when i was a noob) :-)
Post Number: 2567
Canaan has a good one at the sound shop where he works for only $40, prob gonna get that...btw, he said 8ga would be good enough for my system. thank God, cause a 4ga is $80.
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 1039
Ive got the 4 gauge schoche kit it is actually 5 gauge wiring but it works fine for me. The RCAs arent the best but I have never had a problem with them.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12152
wire is wire...Like Isaac said strand count is what really matters
Username: Smoke05
Tucson, Arizona U.S.
Post Number: 386
http://knukonceptz.com/ go there cheaper and better RCA, unless you need them now
Post Number: 2569
cant do knukonceptz. u gotta have a credit card or paypal.
Username: Johnfiac
A-ToWn, 152-153db Da... My wangers b...
Post Number: 2361
SG it melted the fuse holder because the wire was to thin, you really dont want your power wire getting how at all, if it would of got hot somwhere u didnt see and made contact with the frame.... somthing could go but any cable is just about as good as the next stuff... just the flexibility and very very slight voltage drop you might see at the end of the cable as opposed to the alternator..and the heat resistance temperature of it... and resistance of the power wire..which i think is pretty much responsible for the tiny voltage drop.
Goto a local shop ussualy they have rolls of cable you can just by it by the foot..
Anybody got the link for general cable size\length for amount of power needed?
Username: Smoke05
Post Number: 392
http://www.the12volt.com/info/recwirsz.asp
there you go...
Username: Smoke05
Post Number: 393
if you dont have a creditcard apply for one... lol
or just ask someone you know to buy it for you and you pay them in cash... i did that for a friend of mine.
Username: Djhasanicesoundsystem
Vista, Ca Usa
Post Number: 89
or you can use a debit card
Username: J_c_wheeler8
Columbus, IN United States
Post Number: 219
Wolfman.. friends dont let friends shop at walmart...
Username: Adddisorder
West palm, Florida
Post Number: 4056
im 99% sure knukonceptz takes money orders if not go with hifisoundconnection.com they take them
Username: Clouduz
Post Number: 167
yea i get most of my audio stuff from them, recently got some 0ga go with them you won't be disappointed!
Username: Solobaric4life
Post Number: 618
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=15609
there is a good cheap amp kit for 69.99, comes with 20ft 0/1 power wire and everything else
Username: Gh0st_31
FL USA
Post Number: 404
killa i know it wasnt good. This was about 3 years ago when I was a super noob and didnt know any better. I got nice 1/0 gauge now :-)
Username: Riskyb
Post Number: 599
I've got the wal-mart 4 guage kit running 2 400 watt amplifiers and it works fine for me. It's seriously not that bad alot of people go "oh wal-mart sucks that wire sucks blah blah"...wire is wire its all about strand count. For the 800 watts I'm running it works fine. I didn't have to bend over and spend 120$ for some slightly better hooker wiring at the local shop either.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 989
I have used their kit several times for different people's installs. Never once had a problem.
Username: Big_edge_head
Post Number: 60
yeah i got that 5 guage wiring kit too. it works just fine. i got it on a 1200 watt rockford amp. 30 dollars well spent. plus i wanted to get everything hooked up and all i had was like 40 dollars so i said screw it ill just get it.
Username: Johnfiac
Post Number: 2371
As far as buying stuff at walmart... i think the only thing i ever bought there was some live lobsters..... yummy
haha
Post Number: 2571
5gauge?? wtf. never heard of that, it goes from 8 then to 4, can't even find a 6 if I needed it....btw, callled all 3 local audio places and they all said that 8ga would be good enough, even when i go to the 400 watt amp. Canaan said the same thing, and since a 4ga is $80 and I can get a 8ga for $40.......well gonna go with the 8ga
