SSI's or BL's
Username: Northomaha
Post Number: 296
Im thinkin about just sellin my treo TSX's and use what I can get out opf them to buy some BL's i have a visonik 4000d and im wondering if i could match these up with the amp? Id buy the 15's with the flatwind coil and the cooling feature. Would I need to buy anything else and will this work?
Username: Adam_s
15 TC9 Hybrid, RE MT Softparts
Post Number: 1055
Sounds like you have it figured out. A different amp would be nice but it should work.
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 2111
i heard they won't handle 2000, but ask scott not me..
Post Number: 297
well that thing will only do 1500 X 2rms at the max. I think it will do ok. Ive heard good reviews on it. Its definatley not top of the line but its alot of power for the money i paid
Post Number: 298
bump
Username: Adam_s
Post Number: 1058
That amp is supposed to do 3500@ 2 ohms with 14.4 voltage. So with the flat wind coil and the cooling I think they would be able to handle 1700 a piece if you are smart about it.
Post Number: 299
yea i hear they are over rated and ive heard it will do about 3000 at 2 ohms. I will keep the gain low but i know they will handle more power than the SSI's. Will they pound?
Post Number: 302
bump son
Username: Juliob
Santo DomingoDominican Re...
Post Number: 4490
yes
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 162
I know someone with a pair of VR2000s on a single BL 15. [/b]
Post Number: 303
yea i think with the flatwind coil and the cooling feature it will take that power fine. What are the other options for, and also wats the difference between daily and spl configurations for Fi subs.
Post Number: 304
will these things also pound harder than the SSI's?
Post Number: 305
bump, or should i just pony up the money for some btls
Username: Nd4spd18
Southeast PA
Post Number: 1832
2 BLs would be good on that power
Post Number: 307
so final say on this one, 2 15" BLs with which options guys? thanks for the help
Post Number: 308
didnt bump
Post Number: 309
somebody tell me what options i need son
Post Number: 310
bump
Post Number: 312
im just gonna get the btl's itll be a $40 price difference and i wont have to worry about putting to many watts on em. im also hoping they will be louder.
