Solobaric S15D
Username: Kaprese
Walstonburg, NC USA
Post Number: 77
Alright I have a Solobaric S15D (400rms) it's the stillwater (circle model) and the box I have it in is way to big and the port size is to big so should I stuff the box with heavy Books and close the port or should I rebuild another ? and also the sub is facing up towards the reardeck and a slot port facing the right side.....do you think subs hit harder and sound better rear firing? and it's like when I turn on system and step outside the car I barely hear anything and when I get back in I hear the bass alot lot more............so is it because the direction of the sub or the amount power it is getting (like 200w). But my friend has a Visionik 12 and a RF 20w amp and I can hear him before he pulls in the yard and he has a durabrand HU (wal-mart for like 50) it's only 50watts
Username: Mgbcs
Lincoln, Nebraska
Post Number: 918
No books...rebuild that thing.
Username: Ceoofdaroc4
Post Number: 182
Hahahahahahahha I thought my setup was bad... nah jus kiddin yea I wond3er da same thing I have 2 L7's and u can't hear mine as good outside as other ppls systems with way worse setups than I have... I wonder y
Username: Dakangofkrunk16
Earth
Post Number: 585
open the windows then loli had a kicker and i had it installed to face the seat and i would put the seats down from there u can hear it outside alot but kicker suxxed so i sold them but they did help me when i was in need of bass
Username: Mgbcs
Lincoln, Nebraska
Post Number: 920
Isn't the point of the system to hear it INSIDE the car? It's there for your enjoyment...not the annoyance of others. I like bass as much as any of you, but I don't neccesarily want to hear yours in my car.
Post Number: 183
My seats dnt fold
Username: Mgbcs
Lincoln, Nebraska
Post Number: 921
What does that have to do with anything?
Post Number: 184
Dru said he rides wit his seats down so I replyed
Username: Mgbcs
Lincoln, Nebraska
Post Number: 923
Got it...sorry.
Earth
Post Number: 591
then wut u can do is get a bandpass box that gets ported to ur back seats and go thru ur seats to let air in ur cab or get new subs what car u got
im wit ben tho id rather me hear it more than outside reason i rode wit seats down is i felt more bass than wit them up
i want my car to be when u open the door booooom u surprised by the bass thats y edead will be my friend
Username: Kaprese
Walstonburg, NC USA
Post Number: 78
yeah I know it should be played mostly for the enjoyment of me but..... don't sometimes you like to show off just a little. alright and another question WHAT ARE THE POINT OF Y ADAPTORS I know they turn the signal into mono but would this affect the bass production and give you better deeper bass almost like a mono channel amp which to me is made for mostly bass really what I am asking is how will this affect your system (I know this is commonsense for you guys)
Username: Kaprese
Walstonburg, NC USA
Post Number: 79
Yeah DRU I have a Saturn SL2 1998 model it's a small car but I like it my backseats fold down and my HU is Pioneer 2900mp and I have RF 6.5 interior speakers....6x9's don't fit in reardeck but it's a nice car I am trying to fix it up I have 5% tint back windows and 35 up front
Earth
Post Number: 592
alot of people here agree that kicker arent to good but opening the back seats and put the sub in the way back facing the seats that worked really good for me mostly i did it to increase the bass i felt not outside but it got loud outside if u got money u should get a dif sub
Username: Kaprese
Walstonburg, NC USA
Post Number: 80
Alright I will see if I can sell it and the amp and get me a better sub and amp
Username: Nd4spd18
Southeast PA
Post Number: 1581
Good call. And when you do get sometihng better, DO NOT listen to Dru DON"T get a bandpass box!
Post Number: 185
I am getting some new subs I'm trying 2 get two Fi Q's and ill turn my subs around andsee how it sounds
Username: Kaprese
Walstonburg, NC USA
Post Number: 81
Good Looking I will do that I am really looking at the Maw 15's they look decent and I could build a box at my old teacher shop he only charge like $10 a box of any size,shape,or design and you can use all the tools and even the fiberglass
Earth
Post Number: 595
yea dont listen to me on the bandpass i ment just cut a lil port in the back seat that is what ima do more like a long hole that runs in a line friend has a lincon town car he did the same and it gets louder now
but he took back seat out im keepin them in and cuttin thru the seats also then ima put sumtin over it so it doesnt ook like it was cut
http://www.youtube.com/watch?v=dpDLAsANbrM
sumtin like that
Earth
Post Number: 596
http://www.youtube.com/watch?v=dpojnUsgO8c
but that would really only be good wit sq subs there is also this crazy @$$ bandpass boxhttp://www.youtube.com/watch?v=dwbtUqZjxGc
Username: Nd4spd18
Southeast PA
Post Number: 1615
Some bandpass boxes, if built exactly right, can sound good. But 99% are made to be loud at one frequency, and sound like sh!t.......
Username: Kaprese
Walstonburg, NC USA
Post Number: 83
yea you guys are right I will just stick to building my own and can I use plywood for the box ?
Post Number: 189
No you have 2 use MDF like 3/4 I think... its more flexible and airtight and other things but u defintely cannot use plywood...
Earth
Post Number: 606
yea go to local home depot/ lowes and get sheets of 3/4 mdf and dont get birch
Username: Kaprese
Walstonburg, NC USA
Post Number: 91
Alright I did I am going to my old teahcer to Build the 15' sub box.....But if a sub doesn't suppose to be in a ported box can you still do this and it sound good ?
