What kind of subwoofer should I get?
Username: Swansondr
IA USA
I have a 1998 SVT Contour. My audio system so far consists of a Pioneer head unit, Infinity Reference component speakers in front and Infinity Reference 2 way's in the back. Those are powered be a kenwood 4 channel 400w amp. I am looking for a good sub system (sub + an amp) to compliment what I have. I want it to have some kick, but it doesn't have to be so loud that it shatters my back windshield. Anyone have any ideas?
Username: Volfenhagking1600
15 SSD Wangin, Shawano, Wis... USA
Post Number: 590
whats your budget?
Post Number: 591
what do you want spl, sq, or sql?
Username: Swansondr
IA USA
My budget is around 400 dollars more or less. What is "spl, sq, and sql"?
Post Number: 592
spl=sound pressure level
sq=sound quality
sql=both sq and spl
All you need is a sub and amp?
Username: Swansondr
IA USA
Post Number: 7
I want both quality and pressure. All I need is a sub and an amp to power it. I've done all of the wiring already.
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 855
is it 400 for a sub and amp
and just one sub?
Post Number: 594
15" Fi SSD w/ Flatwind Voice Coil
Hifonics BXi 1206D amp
You could get either dual 1 ohm or dual 2 depending on how many watts you wanna give it. With the flatwind it will be able to take 1200 watts. Do you have a stock alternator?
Post Number: 595
that totals to about 500 though...you could look into the audioque sd2.5
Username: Swansondr
IA USA
Post Number: 8
Yes I have a stock alternator and I plan to keep it that way. What do you think I should do with whole ohms thing?
Post Number: 596
well the 15 ssd w/ flatwind will take 1200 watts but im not sure if your alternator will. If you dont want to upgrade your alternator then get the dual 1 ohm sub then you can wire it to 2 ohms to get 900 watts.
Username: Swansondr
IA USA
Post Number: 9
Should I get a capacitator?
Post Number: 597
no
Username: Denali_on_22s
Hit you in the chest m...
Post Number: 1986
^ No. And that amp will prolly only put out about 1000 watts at 1 ohm and 700 at 2... buy a dual 2 sub and wire the amp to 1 ohm.
You don't need a cap... Doesn't really do much...
Username: Swansondr
IA USA
Post Number: 11
Whats the diffrerence in sound between ohms?
Username: Nyyfan13
Fi SSD USA
Post Number: 4759
no difference in sound, just wiring options for your amp
a dual 1 ohm sub will wire to 2 ohms or .5 ohm but you wont wire to .5 ohm
a dual 2 ohm sub will wire to 1 ohm or 4 ohm but youll most likely wire to 1 ohm
Username: Snarl2004
Post Number: 858
ide get:
and wire it to a 1ohm load
it will cost you about 470
if thats to much you can get:
15" audioque sd2.5
and wire it to a 2ohm load
it will cost you about 410
i would reccomend the SSD which will be a little louder but is also more expensive. if its too much for you get the sd2.5.
Username: Reppinqc
Charlotte, NC USA
Post Number: 92
wait. the amp, sub, and the wiring needed for a 1 ohm load would cost him more than 470/410 wouldnt it? that just seems too low to me? maybe im wrong tho
Username: Skibum12189
Cleveland
Post Number: 472
jw, what gauge wire do you have run to your trunk, 8 4 2 0/1?
Username: Dakangofkrunk16
Earth
Post Number: 624
dont forget he needs a subwoofer box i believe
Username: Swansondr
IA USA
Post Number: 12
I THINK I have Kicker 4 guage wire running to the trunk.
Username: Swansondr
IA USA
Post Number: 13
I'm never changing the wiring out of it because it was REALLY hard to wire my contour. The car just wasn't designed to have the stock stereo switched out, I guess.
