Need advice from a box builder logan cannan other ne one
Username: Dakangofkrunk16
Earth
Post Number: 579
what is a good table saw to use im thinkin either dewalt or bosche there good companies can u help me out
im not a begginer with a table saw ive been using my friends for many years and i wanna buy my own any suggestions also what do u use
this will not just be for building sub boxes it will be for many other builds of different thiungs thanx for the advice
Username: Mgbcs
Lincoln, Nebraska
Post Number: 913
I have never used a Dewalt table saw, but I have always used Dewalt for all other tools. They are AWESOME. I would recommend them...
Earth
Post Number: 580
bosche id get this http://bosch.cpotools.com/saws/table_saws/4000-n-rt.html
dewalt
http://www.tylertool.com/dewalt213.html
makita
http://www.tylertool.com/ma2710potasa.html
http://www.tylertool.com/makita71.html
Username: Fi_car_audio
Hades, NV
Post Number: 138
I hate to say it but the Harbor Freight saw I have had for 10 years has been great. Havent had any issues with it and we have definitely cut some wood on that one ;) Decent amount larger than the other table units (floor stander) and we simply built it into a full table to run full sheets of MDF through with one person. About $279 if I remember correctly. Last time I was wandering through I saw the same table there...
Thanks,
Scott
Earth
Post Number: 582
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=45804
scott sumtin like this
Hades, NV
Post Number: 140
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91815
Looked more like that one, but it had a cast iron top and is belt driven. It has been a very solid table. Heck we cut 6 years worth of crates for RE subs and OEM alike with that table, not too mention countless boxes (and I had it for a couple years beofore its tour of duty as the RE shop saw).
HF is like 1/2 mile from the shop... Ill head over there tomorrow and look for the model number.
Thanks...
Scott
Username: Logan__tille
Http://com4.runboard.c..., Imortal Box ... Logan116600@...
Post Number: 6966
Craftsman!!! Thats what I use.
A pic is worth 1000 posts!!
Post Number: 5653
Craftsman for me as well. Been a Harbor freight lover for quite some time. I use their 18v cordless drills alot. I mean, alot. $20 new. Can't beat the prices.
Hades, NV
Post Number: 141
Craftsman does have couple of nice table saws... but the one I have simply wont die, so I havent had a need to get another one ;)
Im sure one day when I do, Ill splurge and get a nice Biesenmeyer or the like square on it.
