Big 3 wiring lengths
Username: Trey4sports
Post Number: 955
im meetin my dad to pickup my range rover and i would like to do upgrade big3 wiring right there but i would like to have the lengths already cut before then. i know ever vehicle is diffrent but what do you guys think is a safe set of lengths?? i was thinkin 4 ft run, 3 ft run, and another 3 ft run??
Username: Th3pwn3r
Post Number:...
Post Number: 1854
MEASURE.
Post Number: 956
"im meetin my dad to pickup my range rover"
dont have my vehicle with me ^^^.....what is a good base number for the measurements as i havent bought the run of 0 GA and dont want to go over just lookin to get fairly close...waht are we talkin here probably 10 ft or so ??
Los Angeles, CA USA
Post Number: 12029
just take the roll with you. how long does it take to cut it and crimp the terminals?
Username: Ctmike
Ct.
Post Number: 3932
i'd just take a measuring tape and measure/cut there. 0 gauge is expensive and you don't want to make any mistakes. plus, even if you cut it at 10ft. now you'll more than likely have to cut it again later, so just get there and make the cuts' once imo.
Post Number: 957
yeah that sounds good, i just dont want to buy to much BECAUSE im going to buy it from knukonceptz so if i get 10 ft and i only need five then i pretty much wasted the other 5ft...anyway i guess ill just measure first then order...ughhh i hate waiting
Los Angeles, CA USA
Post Number: 12030
just buy a roll trey. you can never have too much 0 guage.
Post Number: 958
ehh... when you work for 6.50 an hr and you have to balance a high GPA you can DEF buy too much 0 ga lol
Username: Ridinspinnas
Cayuga, Ontario Canada
Post Number: 82
how much a roll of 0 gauge?
Username: Ctmike
Ct.
Post Number: 3933
depends where you buy it and how much. think it's cheapest at knukonceptz.
http://www.knukonceptz.com/
A pic is worth 1000 posts!!
Post Number: 5555
Every time I order wire, screws, adhesive, carpet, whatever, I always order double what I need. It sux when you're in the middle of a project and you run out of something. Seeing as you could be doing this for years, it just makes sense to buy it at todays prices, if you can. JMO.
Username: Ctmike
Ct.
Post Number: 3936
good point^^. especially since cost of wiring just went up. that's why i'm buying 50, maybe 100ft., of 0 gauge now.
Post Number: 959
yeah thats cool, i understand where you guys are coming from.
Username: Skibum12189
Cleveland
Post Number: 453
"""" ehh... when you work for 6.50 an hr and you have to balance a high GPA you can DEF buy too much 0 ga lol """"
x1000000000000000 ahaha how nice was the 5.15 to 6.85 minimum wage increase
just bought mine for goin distros to amps, but knukonceptz is only like 20 minutes from my hosue but still i know where youre comin from
Post Number: 970
lol, damn ur lucky. the F'n retards are my local shop wanted like 4.90 for kicker hyperflex...dam i kno copper is expensive and all but thats redic
Username: Smoke05
Tucson, Arizona U.S.
Post Number: 339
^ in here thy wanted to charge my $200 for a generic amp kit 1/0. so i bought knukonceptz
