98 cherokee Installing subs on stock HU
Username: Bdbrusch
I just purchased 2-12" subs, an amp, and a head unit. Does anyone know if there is a way to hook up the amp and subs to the existing headunit or do i have ot install the new head unit? if so, how do i go about doing any of this. My car is a 98 jeep grand cherokee
Username: Bdbrusch
Installing the new subs and headunit won't interfere with my existing door speakers will it?
Username: Sinful_systems70
15 INCH WANG...
Post Number: 834
LOC - (Line Output Converter) will get you the RCA's so you could use factory HU.
15 INCH WANG...
Post Number: 835
Here are some... http://www.logjamelectronics.com/liouco.html
15 INCH WANG...
Post Number: 836
Have it installed if in doubt but everything should work fine if hooked up correctly...
15 INCH WANG...
Post Number: 837
Since you are new to this forum, your answers would be faster and more reliable if you post your questions in the Subwoofer section...
