Sub(s) for Hifonics BXi1206D mono amp
Username: B_rad_nep
here are the specs for the amp
Features:
Brutus BXi 1206D
1-Channel Mono-Block Operation
SUPER D-Class Ampllifier Topography
Ultra-Fi MOSFET Outputs
Illuminated Hifonics Logo
PWM MOSFET EXVP (Exponential Vari-Power Supply)
SPC Twin Turbo-Torroids with Simpatico Coil Design
Remote Bass Control Included
Balanced Line Inputs w/ Optional Hifonics MM-BLD-1
Gold RCA Line Ouputs - Permit Amplifier Daisy-Chaining
4-Gauge Power Connectors
Fully Adjustable Accu Cross Crossovers Inlude:
-24dB Subsonic Filter (Adjusts 15-50Hz)
Phase Shift Adjustments (0 to +180 Degrees)
24dB Low-Pass Crossover (Adjusts 35 - 250 Hz)
Bass Boost: Variable Bass Equalization (+18dB @ 45Hz)
SPECIFICATIONS
450W x 1 @ 4 Ohm
900W x 1 @ 2 Ohm
1200W x 1 @ 1 Ohm
S/N Ratio : >95dB
THD & Noise : <0.08%
Heat Sink Dimension : 11.41" x 2.63" x 10.39" LHW
My budget is $300 and i'm either looking for one 15" sub or two 12" subs.
i was thinking maybe a 15" Kicker L7 or a couple 12" alpines (perhaps type Rs). i want loudness mainly. any constructive criticism?
