OT: lowering a 4x4
Username: Talon_es93
Trinidad, Co
Post Number: 607
would i jack up anything on my blazer if i was to put 20"s on it and lower it 3" on the front and 2.5" on the back... during winter i would lift it back up to reg. hight
Username: Homegrowncam
Funky Town, TX United States
Post Number: 402
firsr off i would say no but wahts the point in lowering a 4x4?
Los Angeles, CA USA
Post Number: 11661
don't lower it. raise it. lol.
this pic belongs to jessie D. you cannot use this pic without the written consent from jessie D.
Username: Gavbo211
JL Audio 10w3v2, IL US
Post Number: 412
no, it's quite possible to do, although it would jack up my feelings and completley ruin the point of the 4x4.. lol. just look for a drop kit for a 4x4 blazer from your model year. i'm sure you can find one pretty easily. also, be sure make sure the 20's will not rub the wheel wells when you turn if you drop it, that's something most people don't think about when dropping cars and adding big rims.
Username: Freezeman_7
Lindsay, Oklahoma U.S.A
Post Number: 823
thats what i was going to ask you. there is not point
Post Number: 403
how about just get a air lift kit and you can raise and lower it all year round.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 620
I like raised trucks...just my opinion.
Username: Dakangofkrunk16
Post Number: 248
Certain Trucks i liked raised and certain ones i think look betta lowered my friend has a blue chevy tahoe lowered and it look really sexy now and f 150-450 jacked up is ment to be
Post Number: 249
but now ur's can look both good lowered-http://www.minitruckinweb.com/features/0307mt_1989_chevrolet_s_10_blazer/
And Raised-http://www.mrmoms.org/OcalaTrip/BlazerHers.jpg
GetTTER DONE
Username: Matt12490
California USA
Post Number: 2080
Both of those trucks are damn ugly.
Post Number: 255
Those r just two examples a lowered and a raised car thats it pay no attention to the car paint or w/e else i no they both ugly look at what were descussin one lowered on raised
Username: Sheriff
Post Number: 242
Raise the mofo and throw on some 44" tires
Los Angeles, CA USA
Post Number: 11671
this is what you should do with a 4 x 4.
Trinidad, Co
Post Number: 608
but its a lil blazer... i think they look ugly lifted... i even thought they looked ugly with big rims till i saw one... but someone told me that the old blazers have 2 bolts on the front that you can loosen to drop 2 inches so i might just get 2" blocks for the back
Trinidad, Co
Post Number: 609
http://www.cardomain.com/ride/764273
Username: James1115
Use a simple...
Post Number: 9784
I have lifted many vehicles and its not as easy as lowering it for the summer and raising it for the winter. Unless you put in airbags and you wont get a drastic drop or increase in hight but you will get a better ride. To lower a car you need to cut the existing springs or get new ones, change the upper and lower control arms, change the sway bars, and new trac bar. I love lifted trucks, I have had a few in the past, aswell as curent. That pic of the old bronco is SWEET:-)
Trinidad, Co
Post Number: 610
i like lifted trucks to and lowered.. and sports cars.. and lowriders... i like different style for different cars and in my eyes a blazer should be dropped.... now if i had a 2500 hd desiel duramax then that thing would be in the air.... and the honda i have has a full body kit... and the regals and impala i have got spokes on them... andd for some reason i think the blazer should be dropped... i feel the same way as you guys about droppin a 4x4 but i just don't see this one lift sry... and thanks alot for all the help
Username: Skies
Courtenay, British Colu... Canada
Post Number: 492
Longo, whats your favourite truck to lift?
Doin my 96 f-350 now :P
Next project: 2007 Chevy Colorado ( or gmc canyon, w/e.)
Trinidad, Co
Post Number: 611
oh ya i forgot to ask.. do any of you guys know were i can get a roll pan for this with the side caps... its a 97 blazer
Username: James1115
Use a simple...
Post Number: 9788
if you really want to drop a blazer I suggest you go 2wd, without the front drive shaft and transfer case you can get it lower. I like the fords lifted, but my favorite would have to be my dodge ram 2500 quad cab lifted 3 inches on 35's:-) another one of my favorites is the good ole wrangler done up right. here are a few pics of my last vehicle and my current
Username: James1115
Use a simple...
Post Number: 9789
Username: Th3pwn3r
Post Number:...
Post Number: 1639
"a few pics of my last vehicle and my current" I only see one picture!!!
Username: James1115
Use a simple...
Post Number: 9790
Username: James1115
Use a simple...
Post Number: 9791
my computer is acting up and wont let me re-save the images as I shrink them to fit punk!
A pic is worth 1000 words
Post Number: 5096
^^^^Now that looks like fun!
Username: James1115
Use a simple...
Post Number: 9792
I will add more tomorrow I just got a new hood put on so I have to take a few:-)
Post Number: 5097
Here's my truck:
Username: James1115
Use a simple...
Post Number: 9796
Username: James1115
Use a simple...
Post Number: 9797
nice truck Paul:-)
Post Number: 5098
Nice.
Post Number: 5099
Yours is nicer, by far.
Username: James1115
Use a simple...
Post Number: 9800
its a worker:-)
Username: Renegadesrun
Lafayette, IN US
Post Number: 682
Chad.....the big lifted truck had no driveshafts.
Which is about as far as most ppl get when they realize their extreme lift ended up being a bigger PITA than was imagined.
Username: James1115
Use a simple...
Post Number: 9804
exactly, when you have to deal with drive shaft angle corrections it becomes a huge headache. I had to do a transfer case drop kitin my jeep to help account for the angle because I got a hell of a vibration untill I fixed it.
Username: Bernymac
Cambodian
Post Number: 2322
Hmmm. I don't care what anyone says. thats a mid sized suv. its a blazer. which is like the s10 but a suv. the s10 xtreme and blazer xtreme are bad a z z. You need to drop that b!tch on some 20's atleast. www.performancecenter.com I would do shackles in the back if you can and springs in the front. Check what you can go.
Trinidad, Co
Post Number: 612
thanks berny... see me and him are alike... he got the subs that i want... but now i can't get it... my girlfriend says thats to much for a single subs so imma have to settle for 2 cvxs... i'm sure i can still do a few numbers tho with those and they'd still be a good upgrade from my cvrs..... but ya.... he's also a chevy guy.. (i think b/c of his bad azz ride)
Username: James1115
Use a simple...
Post Number: 9810
but the xtreme's are 2wd Berny so they are much more compatable with being lowered.
Username: Joebruce
U.S.A.
Post Number: 501
Go to www.summitracing.com for a lowering kit,Belltech is the best. I got my 3/3 kit there with shocks for 250-260 i forget. For a roll pan go to www.suicidedoors.com thats THE place to go for all truck stuff. BTW why 3" front and 2.5" in back? The back of mostly every car/truck sits at least 1.5/2" higher in the back it would look bad doin 3 front and 2.5 back IMO. My s10 is 3/3 and the back is still way to high for me. And the easiest and cheapest way to lower it would be springs up front and blocks in the back.
Username: Joebruce
U.S.A.
Post Number: 502
Dont forget about some nice shocks! Toxic drop shocks are good or Belltech.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 639
Kinda late...but nice truck James! Awesome...
Username: Bernymac
Cambodian
Post Number: 2323
I don't really see anything wrong with dropping a 4x4 4wd or w/e. Escalades are 4wd and people drop them. If you aren't using your car for 4x4 use, then drop it. whats wrong with that. Now you have a high gripping, lower gravity vehicle =).
Username: James1115
Use a simple...
Post Number: 9837
when people drop escalades berny they are the 2wd models they drop(atleast the smart ones) there is to much to get in the way with a 4wheel drive truck to lower it.
