I need some help!!
Username: Thump510
Oakland, Ca U.s
Post Number: 27
how do i connect turn on wire and do i need 1 also how do u connect wire to fuse holder thx!
Username: Illuminator
Post Number: 4929
The remote turn on wire? It's only necessary if you have an amplifier. Don't get in the habit of thinking every wire needs to be hooked up--it can be damaging. :-)
There are a couple of ways to connect a wire (I'm assuming your yellow battery constant):
Built in tap on the fuse:
Different kind of tap built in:
My personal favorite and probably the cheapest, a simple metal tab that you can slip on any existing fuse.
