Solid head unit !?!
Username: Trey4sports
Post Number: 768
im lookin for a good head unit that has a USB that will support a 40 GB MP3, i see a lot of HU's that support like a 4GB MP3 player, but i wanna get a bigger one so if u guys could point me in the direction of a HU that fits my needs. budget is really anything under 300
Username: Snarl2004
Audioque 12 SD2.5s, Earthquake P...
Post Number: 719
i dont no of ne that support a 40g mp3 player but i got a jvc that i put a connection in the back with makes it rca and then i can play my ipod through that. i prob spent around 200 for everything.
Username: Snarl2004
Post Number: 720
i got this and it works with any jvc hu with a cd changer port in the back.
http://www.crutchfield.com/cgi-bin/ProdView.asp?search=jvc+rca&i=469JVCJRCA
Post Number: 769
hmmm im an ipod hater, but thanks for the help dude im sure ill find a way to make this work
Post Number: 770
so if i hooked that to the back i could just hook an IPOD up to it and it would work ??
Username: Snarl2004
Post Number: 722
u could hook up any mp3 player that has a headphone jack if you get something like this
http://www.amazon.com/Monster-Cable-126130-iCable-iPod/dp/B000068IH5
i doesn't have to be this cable either theres tones of em around. they also make different adapters for different stereos so it doesnt havce to be jvc i just personaly like the look of them
Post Number: 772
does it decrease SQ ??
Username: Snarl2004
Post Number: 723
no. its the same quality that would play through CD's or you would listen to through earphones on an mp3 player. ive noticed no sq loss and i assume it would be the exact same sound as a usb connection
Post Number: 773
so when your bumping to an uncompressed file straight from CD is there a big difference when you go to compressed music file like an MP3 ??
Username: Tatonka
Post Number: 37
Either way its probably 128kbs, so there is no quality difference.
