Wiring subs with varying impendances
Username: Mercsable
Post Number: 43
Where can I find how to wire 2 different subs with 2 different impendances...for example, I have one sub that is 4ohm DVC and one sub that is 2ohm DVC and I want to wire them both to one amp if this is possible.
Username: Hockeyknight
Post Number: 980
i think theres a calc on the rockford site but idk about mixing the subs...are they the same subs or whats the story with this one??
Username: Mercsable
Post Number: 44
well one of the cones to my sub tore and I had this other one lying around and i was wondering if i could wire the 2 together even with different impendences.
Username: Imalik
Jackson, New Jersey Ocean
Post Number: 160
Here you go. Im not sure that mix will work
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Username: Johnfiac
IL My wangers b...
Post Number: 1935
Just a FYI, its not reccomended to mix subs, expeccialy on the same amp. SQ\SPL difference cancelation..ect all depends tho
Username: Van_man
Boston South, MA
Post Number: 2234
Wire the dvc 2 to 4 ohms, then wire em all down to 2.6 ohms
Pretend you wired the 2 dvc to 4. (sub 1)
Then each 4 ohm coil of the other sub (sub 2)
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?ampt ype=mono&suboptions=Mono_3-4ohm-SVC
That will get the most out of your amp at close to 2.5 ohm load.
But like ^^^ said, mixing subs can cause ill effects.
But it can be done.
Username: Van_man
Boston South, MA
Post Number: 2235
But it can be done.
