Images help...
Username: Mgbcs
Lincoln, Nebraska
Post Number: 488
I'd like to post my pics of the box I am completing, but I cannot get them to upload. Do I need to shrink them down to like 600x600? If so, how do I go about doing this? Thanks!
Username: The_image_dynamic
San Diego
Post Number: 576
They have to be 600x600 or less and 90k or smaller. The way I have resized photos for years is with IrfanView. It is the very first thing I install on all my builds. You can get it here:
http://www.download.com/IrfanView/3000-2192_4-10608664.html?tag=lst-0-1
Username: Nd4spd18
Southeast PA
Post Number: 935
Yes. If you don't already have an image editing program on your computer, I recommend IrfanView:
http://www.irfanview.com/
It's free and easy to use. To resize a picture, open it up in IrfanView, press Ctrl+R, enter 600 in the width box, and hit ok. I recommend you then save it as a jpeg with the default quality, since this forum also has a file size limit.
Username: Nd4spd18
Southeast PA
Post Number: 936
Damit Brad beat me to it! lol
Username: Van_man
Boston South, MA
Post Number: 2202
Open it in paint, Go to image > streach and skew.
If I use my camera, i streatch and skew pic 46x46
If I use my wifes camera, I do 24x24. Then save as Jpeg.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 492
Thanks Marc...thats by far the easiest!
