How to turn off the Dual XDVD710:
Username: Amccullough11
Florida USA
This might be a dumb question but for some reason the dual XDVD710 won't turn off by it self, I have to manually turn it off. I have checked all my wires and it's hooked up right it just won't turn off when I remove the key. Any advise would be great thanks.
Username: Sgt_hobo
Post Number: 7
switch the two main power feed wires. did the same thing on my dual
Florida USA
Thanks I'll give it a try
Florida USA
Okay switched the two mains and now I have another delima. When the radio turns off nothing is saved?
