What size cap?
Username: Loud_proud
i have a 410 w amp rms and 1000w peak what size cap do i need i've heard u need 1 fader per 500w but is that peak or rms?
Username: Mateo
Post Number: 136
you dont need one at all...but is a fared...not fader just sos ya know
Username: Nd4spd18
Southeast PA
Post Number: 764
http://www.wickedcases.com/caraudio/capacitors.html
Username: Mateo
Post Number: 137
correction...*farad* not fared haha my mistake
Username: Skibum12189
Cleveland
Post Number: 312
you can buy my 3 farad capacitor for 50 bucks
Username: Nd4spd18
Southeast PA
Post Number: 781
thats 50 bucks too much for something that does nothing
Username: Arande2
Extreme SQ FTW
Post Number: 1859
You should invest in a 100 megaton self-powered trailer which holds 100 lumafarads (It goes deka, hecto, kilo, mega, giga, tera, exa, zetta, yotta, zona, weka, vunda, uda, treda sorta, rinta, quexa, pepta, ocha, nena, minga, THEN luma... in other words...HUGE, one lumagram is like...at least the earth once...at least) of power maybe??? I'm sure it's enough to power the world for a while..
Username: Arande2
Extreme SQ FTW
Post Number: 1860
I want one of those to make a taser with.........
Username: Killswitchjd
Post Number: 293
wtf lets get a new hobby instead of listing 20+ prefixes
Username: N2audio
Lawrence, Ks USA
Post Number: 1230
"...It goes deka, hecto, kilo, mega, giga, ...THEN luma"
too much googling can cause blindness --
So I've heard.
Username: Fishy
Tamarac Ft.Laud, FL USA
Post Number: 1565
I had a 2 farad cap in my last install. Not saying it didn't help transients SOME, but it sure wasn't worth the effort. It was a real PITA to have to discharge/recharge the thing through a light bulb every time I disconnected/ reconnected power at the battery to work on things.
Going to spend over 3 grand on my new system, none of which will be going towards the purchase of another power cap.
:P
-Fishy
