Amp for a D9
Username: Driveslow
I just got a Diamond Audio D9 Sub and was wondering which amp to get for it. I was thinkng the D6 but should I be considering anything else?
Username: Oglejust
You aint bangin unless..., Il
Post Number: 1074
whats the rms? and vc configuration
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 8
i got a ? i got 2 12"Quantum and a usamp 2000D and i'am tradeing my 2 Quantum for 2 12" RE SE + $350 for then should i do it or not??
Username: Oglejust
Post Number: 1075
sure
Post Number: 9
will i blow them??
Username: Driveslow
rms 600
does vc mean voice coil? cause voice coil on it is 3.5in
Username: Oglejust
Post Number: 1076
i mean is it a dual 2 ohm? and to quentin id say just b careful
Post Number: 12
what if i get the re se will the blow?
Username: Driveslow
yeah its a dual 2 ohm
heres a review with more info if you need it
http://www.icixsound.com/vb/article.php?a=11
Username: Oglejust
Post Number: 1078
if ur careful u wont blow them
Post Number: 15
thanks the guy that saleing them said that they wont blow
Username: Oglejust
Post Number: 1079
1000wrms at 1 ohm will work
Username: Oglejust
Post Number: 1082
ya the d6 will work... http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2696
Post Number: 19
ok thaks that how i got my Quantum
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 1060
not to be a jerk quentin but, start a new thread when you have a question man
Post Number: 20
my bad
Username: Blainew
Post Number: 2173
Quentin do not trade your two subs plus 350....check on ebay..youll get both those subs for around 350
Username: Driveslow
well thanks for the help.. im still confused why 1000 @ 1 ohm will work on a sub thats rated at 600, guess i need to do some more reading online
Username: Oglejust
Post Number: 1085
because that sub can take more than its rms
Username: Oglejust
Post Number: 1087
hes trading his subs for 2 diff. subs and 350... hes getting the 350.
Username: Driveslow
Post Number: 7
ok thanks. are there any cheaper options for the d9. im prepared to spend that much, but if there is something comparable for less.. why not?
Username: Oglejust
Post Number: 1088
yeah theres a lot cheaper amps out there ill look for some.
Username: Oglejust
Post Number: 1089
memphis mcd1000d
ed nine.1
hifonics 1206d
Username: Usask8er1
15 Orion H2 on a 2500d, 4 15 ID SPLs 15 INCH WANGERS
Post Number: 755
interfire 1000
Username: Oglejust
Post Number: 1090
interfire? do u mean crossfire?
Username: Usask8er1
Post Number: 757
no interfire, our local shop carries them and there great amps. heres on model available this thing is a beast http://cgi.ebay.com/Interfire-IFB-2340C-2-1CH-Big-Boy-2200W-Power-Amp_W0QQitemZ1 50092395381QQihZ005QQcategoryZ18796QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Oglejust
Post Number: 1093
that amp wouldnt work... not only is it a 2 channel<not needed + it isnt 1 ohm stable
Username: Oglejust
Post Number: 1094
ok i see 1100wrms at 4 ohm now ok ya that would work but i would get 1 of the 1s above
Username: Usask8er1
Post Number: 759
well they have a 1000 watt at 1ohm usually on ebay for 150 but there anrt any up right now
Username: Oglejust
Post Number: 1096
hmmm seems too cheap... u sure they do rated power?
Username: Usask8er1
Post Number: 802
yea my buddys got one and it pumps his two orion hp 12's like crazy
Username: Usask8er1
Post Number: 807
didnt bump
Username: Usask8er1
Post Number: 901
bump damnit
Username: Driveslow
Post Number: 8
wow you guys are amazing. I looked at those choices, and I'm seeing those amps for about 200-300 on ebay, are those good prices? I know the D6 is a bit more, although I found on ebay for 300. I'm looking to pay around 300. Is the D6 th best for my sub becasue it's also a diamond audio? or does it even matter?
Username: Driveslow
Post Number: 9
would the orion 1200D work or would that be too much power?
Username: Driveslow
Post Number: 11
bump
