2005 Ford Taurus
Username: Jcramos
New Jersey
Hello, I need help with my OEM Radio. I have a 2005 Ford Taurus and I want to install a Wired FM Modulator Relay for my Sirius Radio. Its very simple to install, just plug in the Antenna end into the Modulator and back into the radio.
My problem is that my OEM radio doesnt have an antenna end.
1) Where is the Antenna?
2) How do I connect the Wired FM Modulator Relay to my radio?
3) Is there a wiring diagram someone has?
Thanks
jcramosUpload
Username: Leew
XXXX!!WWWW, Yokosuka, ... Holla Back Y...
Post Number: 1353
the antenna module is located separate from the hu.
