Anyone please help
Username: Tallaballa
Lino Lakes, MN United States
Post Number: 32
Does anyone no any good sites that i can give them the specs on my sub and they will make a quality good box for my subs or does anyone know any good places to buy boxes
Username: Rosrock2000
Notre dame!USA
Post Number: 269
what sub?
Username: J_baby15
Kentucky
Post Number: 1237
theres a couple sites that make really good boxes but they're pretty expensive. ppl on here can help u design one to build urself if u want, theres also a couple that may build one for u a lil cheaper than a site would.
Post Number: 33
i am goin to get 2 alpine type r dual 2 ohm subs
Post Number: 34
aight thanks jordan anyone else no any sites i could buy a good quality box
Username: Ctmike
Ct.
Post Number: 3326
http://www.woodlawncabinetry.com/index.html
http://www.spkrman.com/
Post Number: 35
Well i am sorta on a budget so idk wont those custom boxes cost a ton i want a good box for like 175 and under are there any good boxes for that
Username: Ctmike
Ct.
Post Number: 3329
either make one yourself or have one made. couple of people here make them for others. start a thread for one. but even going to an audio store, unless they're complete as_holes, you should be able to get a dual ported box for that price.
Post Number: 36
aight thanks
Username: Phil_salisbury
Post Number: 170
Matt,
Shoot me an e-mail with the maximum dims for the enclosure and spec's you require for it.
I'll hook ya up.
Post Number: 37
aight phil whats your email adress
Post Number: 171
woodlawn.cabinetry@verizon.net
