Budget $$$150-200$$ 5.25 components
Username: Jkidder
Spring hill, Florida Usa
Post Number: 288
lookin for pretty loud 5.25 components n' i have amp already. 100x2 @ 4 ohm n' another amp thats 55x4 @ 4 ohm. so w/e u can suggest. must be loud too because i will have a 15" FI Q running.
Username: Jkidder
Post Number: 293
bump b!tches. some1 help. alter? anyone?
Username: Alteraudiousa
Concord
Post Number: 1439
well i'd suggest some but with the power ratings your budget and your expectations it might be hard to get a set to fit them all. I have a hard time getting a 3way setup to evenly match my Mag 15! I guess since you have two amps you could do an active setup which would be nice. I'm sure we can figure out something...if you can save about 100$ more for a little better range of speakers to hold its own against the Q though.
