Box for a 12" Kicker Comp
Username: Gibson5469
Post Number: 59
I need help designing a box for my 12" Kicker Comp ( 4 ohm) . I was leaning towards a sealed enclosure but I'm open to suggestions.
Thanks.
Username: Logan__tille
[:-]15 Wangers Club[:-] Premier Member
Post Number: 5378
dont seal it.
Username: Oglejust
You aint bangin unless..., Il
Post Number: 792
2.5 cubic foot tuned to 35hz
Post Number: 5379
make this box http://www.subwoofertools.com/forum/ported-box.asp?Ew=25&Eh=14&Dia=6&Xmax=14&Vd= .11&NumW=1&Vb=1&Fb=40&Qts=&Vas=&Fs=&CE=0
Post Number: 5380
NNOOOO^^^^^^
this one...
http://www.subwoofertools.com/forum/ported-box.asp?Ew=25&Eh=14&Dia=6&Xmax=14&Vd= .11&NumW=1&Vb=2&Fb=40&Qts=&Vas=&Fs=&CE=0
Post Number: 60
Oh and is it ok to leave the kicker mounted inverted like this for a little while? The back of the box was way too close to the basket, and just too small in general. It was making my amp go into protection mode.
Post Number: 5382
I dont see why it would hurt it.
Post Number: 5383
Wheres your amp?lol
Post Number: 61
The amp is under my rear seat.
Post Number: 64
I changed the xmax to the spec that kicker gives (9.76mm) and got this for a box design.
http://www.subwoofertools.com/forum/ported-box.asp?Ew=25&Eh=14&Dia=6&Xmax=9.76&V d=.11&NumW=1&Vb=2&Fb=40&Qts=&Vas=&Fs=&CE=0
should I use that instead?
Username: Oglejust
Post Number: 793
no make mine :-)
Username: Oglejust
Post Number: 794
here 3 in port :-)
http://www.subwoofertools.com/forum/ported-box.asp?Ew=25&Eh=14&Dia=6&Xmax=20&Vd= .11&NumW=1&Vb=2.5&Fb=35&Qts=&Vas=&Fs=&CE=0
Post Number: 5389
no lol bulid mine.
Username: Oglejust
Post Number: 796
no dont listen to logan... hes got long hair!! build mine i had a 12in kicker comp in that same box and it slammed for what it was.
Post Number: 65
so it doesn't matter that your box has 20mm for the sub xmax, when kicker specifies 9.76?
Post Number: 5390
LIER!
Post Number: 5391
it just makes the port bigger
Username: 54danny54
KY More Wang Th...
Post Number: 3407
http://www.subwoofertools.com/forum/ported-box.asp?Ew=25&Eh=14&Dia=6&Xmax=50&Vd= .11&NumW=1&Vb=1&Fb=40&Qts=&Vas=&Fs=&CE=0
build that 1
Username: Oglejust
Post Number: 799
lol ^^^^ no but mine is the best design
Post Number: 67
For this box, that Logan designed, where should I cut the hole for the sub? on the black or red side?
One more thing, I listen to mostly rock, techno, and occassionally rap. Will I lose alot of that tight/accurate bass by using a the ported box, I linked above, instead of a sealed enclosure?
Username: Mygame5982
Memphis HPO 15 Wangers..., TEXAS US
Post Number: 1169
lol...nice little sub...better then no bump at all!! my friend has three twelves like that..they sound cool
Post Number: 68
yea I like the kickers. cheap, and get the job done well. i don't like spending money on this stuff anymore (sold my entire alpine system) so between my boston acoustics (front speakers only), the amp, and this sub, I've spent a total of $40
Post Number: 72
Logan: One more thing, I listen to mostly rock, techno, and occassionally rap. Will I lose alot of that tight/accurate bass by using a the ported box, I linked above, instead of a sealed enclosure?
