Which Is The Better Sub To Get ?
Username: Foong_one
I'm going to get a single 12" sub. I have already narrowed my choices down to these two, but just can't make up my mind between them (even though they're priced differently, the price is not a consideration). Does N-E-1 have an opinion ?
MTX Thunder5500 T5512-04, OR
Alpine SWR-1242D
Username: James1115
Use a simple...
Post Number: 8826
I would take the type R over the MTX all day long.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 11168
"the price is not a consideration"
Honestly both of those subs sux...how much $$$ u got??
Username: Tanmanfosho
Fi SSD15 Wangers
Post Number: 590
x2 the alpine isnt too bad but u can get wayyyy better for ur money so give us your budget
Username: Alexv305
Tavernier, FL USA
Post Number: 559
For the same price and WAY better SQ get hooked up @ www.ascendantaudio.com
Username: Foong_one
Hey, The End, if they both suck, then tell me what you think would be a better 12" to get in that price range (that is, $120 - $200).
Username: James1115
Use a simple...
Post Number: 8828
I disagree with Chauncey, and biggs. You can't get much better for the money, and for the money alpine type r's don't suck. They are one of the best budget subs available.
Fi SSD15 Wangers
Post Number: 591
fi is better and its still budget
Fi SSD15 Wangers
Post Number: 592
yo fi caraudio www.ficaraudio.com check the SSD out FTMFW
Username: James1115
Use a simple...
Post Number: 8832
FI what model? you can get a type r 12 for $115 shipped
Fi SSD15 Wangers
Post Number: 593
u cna get a fi 12 for 189 and its better
Post Number: 11176
Sorry, if i feel that all "budget" subs are sh!tty...Just save....then there is no need for "budget stuff"
I no everybody doesnt have money...but show some discipline and save
Nj US
Post Number: 2892
To me. Buying crappy equipment is nothing short of a cheap education. Obviously cheaper to take the advice of the experienced, but some only learn by failing. Their loss. I have learned this very same way. Education can sometimes be painfull.
Fi SSD15 Wangers
Post Number: 596
soo an fi SSD is budget? they may be cheaper but...
Username: Foong_one
You guys are not answering MY QUESTION. Please, for the sake of audiophilism, just tell me which of those 2 subs is the better one: the MTX, or the Alpine Type-R ? Thank you, thank you, thank you.
Nj US
Post Number: 2895
Alpine. Sir.
Username: James1115
Use a simple...
Post Number: 8851
I already said ALPINE
Username: Rovin
1 12 Atomic ...
Post Number: 10497
u tell em James cause im really tired of typing that here to ppl so i've stopped
to answer the ? - of ur 2 choices >>> Type r hands down .......
