Custom Treo SSX\CSX
Username: Johnfiac
IL Afghanistan,...
Post Number: 933
Has anyone seen this custom sub on ebay? Looks pretty massive.. you think its loud?
http://cgi.ebay.com/Custom-Treo-bad-a-subwoofer-SSX-CSX_W0QQitemZ280066543705QQi hZ018QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Denali_on_22s
SSX, Tenneki US of A
Post Number: 817
very pointless... its got daily beating softparts but the motor cant be or isnt often used daily because it has bad cooling... it should be teh opposite, or so you would think.
but yes it would get loud
