I'm making a vented subwoofers box need HELP!
Username: Lt_450r
North branch, Mich. Lapeer
Post Number: 48
I been pricing around stores for vented subwoofers boxes 12' but they all cost from 100.00-250.00 dollars and i can make a box myself for at least 80.00 but i don't know how to find out what the depth got to be and volume of the box either, Can anyone help me with that i got 2. 12' M1 memphis.
Fi Audio BTL
Post Number: 8792
http://www.the12volt.com/caraudio/boxcalcs.asp
http://www.subwoofertools.com/forum/ported-box.asp
http://www.carstereo.com/help/Articles.cfm?id=31
and after you finish building your box and you need to set the gain to your amp.
http://www.subwoofertools.com/forum/setgain.asp
Username: Frkkevin
Post Number: 2471
^^ .. great links .. take the time and build it yourself.. well worth it!
Username: Lt_450r
Post Number: 49
well right now i have a sealed box. It will be awhile for me to get a vented box, i was going to dill one big hole on a side of the box so i can breathe lil bit. will have be a good idea until i get my other box?
Fi Audio BTL
Post Number: 8817
you can't just drill a hole and be done with. it will sound terrible.
if you want to convert your current seal box to a ported then i suggest you use a 3 inch pvc pipe. get the volume of your box then determine what tuning you want. then cut a hole to fit a 3 inch pvc pipe on your box. then cut the pvc pipe to the desired tuning and stick it in the hole.
