Using Morel Elates with a K2P component set...??
Username: As007
I have a 2001 330Ci and fitting the K2P 6.5 mids into the door panel is very difficult it will require some custom work to the door panel, so I was wondering if I installed the TN52 tweeters, focal crossovers, and used the pair of Morel Elate 6" woofers I have for the mids since they are not as deep.
Username: Adddisorder
West palm, Florida
Post Number: 2653
the crossover points for the morel woofer are probly diffent then the k2p so you might want to consider going active. if not yes it will work and chances are it will sound fine, but if you crossed it over properly it would sound better
