Box desgin help. Anyone?
Username: Tanmanfosho
C Bang, Hardcore Iowa USA
Post Number: 271
Alright here's the deal. I'm going to install a 12 inch FI SSD in a GMC Jimmy. I'm thinking ported tuned to bout 33hz or something. But i've never designed a box before. anybody wanna help. liek plans or soemthing thanks
Post Number: 272
here's the specs for the woofer
Fs: 27.0 Hz | 26.3 Hz
Re: 0.75 Ohms/coil | 1.5 Ohms/coil
Qms: 4.60 | 4.71
Qes: .52 | .49
Qts: .47 | .44
Mms: 192g | 201g
Cms: 0.18mm/N | 0.18mm/N
Sd: 480cm^2 | 480cm^2
Vas: 58.7 l | 58.7 l
Spl: 85.3dB 1W/1m | 85.3dB 1W/1m
Bl: 9.3 N/A | 14.1 N/A
Xmax: 21mm
Rms: 800W
Sealed box: .8-1.6 cuft
Ported box: 1.8-2.5 cuft @ 33Hz
Sub OD: 12.500"
Cut ID: 11.125"
Mounting depth: 6.500"
Displacement: 0.14cuft
so it recomends 33 hz... anybody got any plans or can tell me how to build one and materials. thanks
Fi Audio BTL
Post Number: 8730
how about something that will look like this. the pic is a view from the top. the sub would fire to the side and the port to the back.
Fi Audio BTL
Post Number: 8734
first decide what kinda style box you want. slot port or aero ports. after that decide which way you want to fire everything. like the sub and the port.
the picture above is an idea i saw somewhere. its something i want to try out in my friend's suv.
Post Number: 274
im pretty open open to ideas. i want a sloted port though. And i think i want it firing up but idk where the port should go. your tyhe expert not me. what do you think would be loudest?
Username: Nyyfan13
Fi SSD USA
Post Number: 2001
guess i talked you into the ssd huh?
Post Number: 275
defiently yanks i was jsut thinkin bout it then after looking at it and u sayign soemthing i was sold ive got 400 bucks and wotn take me too logn to save for the rest
