How is this going to work?-=-=-
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 566
okay im gettin a solo x 18 that is dual 2 ohm and im gettin 2 2500 orion amps to power this baby up but here the ? how am i goin to hook both amps up to this sub so it can see 5000k watts
Username: Bump05
We Stay Fly, 18 SX USA
Post Number: 565
hook one amp up to each voice coil
Username: Oglejust
RE SX, USA, Il
Post Number: 523
1 to each vc. its not 5000 watts its watever it does at 2ohm x2. just make sure u set the gains the same.
Username: Oglejust
RE SX, USA, Il
Post Number: 524
d@mn it spl!!!!! lol u got to it 1st
Post Number: 567
oh so u mean it wont see 2500 watts on each coil so it wont do 5000k watts on the sub if there is a way tell me how
Post Number: 568
Username: Oglejust
RE SX, USA, Il
Post Number: 527
you cant w/ that vc configuration ull just have to put 1 to each vc if u get that setup... wat does the amp do at 2 ohms?
Username: Oglejust
RE SX, USA, Il
Post Number: 528
ull get like 3400-3500wrms
Username: Waterboy2289
Martinez, Georgia USA
Post Number: 148
thats probably a good thing because the solo x 18 cannot take 5000w for daily even though it says its 5000w rms
it is VERY important to make sure the amp settings are the same when using 1 amp per coil
Nj US
Post Number: 2127
Wow guys. Competing on who helps first? Quick responses, both of you...Upload
Post Number: 569
well what amps do 2500 watts at 2 ohm's?
Post Number: 150
tyler...whats the purpose of the solo x 18...competition, daily, or both?
if competition then 5000+ watts is fine
if daily then shoot 3000-4000(tops)
have you considered the electrical system?? defiantley need an ho alt and depening on its size, a deep cycle battery or 2
Username: Jblanford
Post Number: 149
a massive p.3000.1 does 3000 @ 2 ohm if you have the electrical upgrades to handle that
Username: Bump05
Post Number: 574
imo i would not do 2 amps on one sub its too hard for someone who dont really know what there doing to set everything perfect...id only use 2 amps only for burping and comps other then that daily and some comps id go with one amp like joe just said massive would be my best bet for that sub
Username: Kravenblood
Ohio
Post Number: 150
Get a dd z1 like me 3000rms at 1 ohm lol
Username: Johnfiac
IL USA
Post Number: 777
If its a DAUL 2 OHM then why just get ONE amp that does like 3000@2ohm ?? Just get a DUAL 1 OHM soloX18 and 2 earthquake 10000w\2 amps strapped togethor with the sub in series to be 2 ohm, the amps will do about 6000rms to it at 2ohm, just watch how loud you turn it up so you dont over power them to bad..
Ohio
Post Number: 151
Earthquake dont really back there products anymore i read an article of someone that used there amps and earthquake made promisses to him they didnt keep like haveing a tech at a comp since he was haveing truuble with there amps took 4 months for his amp to get fixed and a bunch of other problems anyway the z1 is 3000 rms at 1 ohm and was told peoples been getting up to 5k rms on the amp
Username: Johnfiac
IL USA
Post Number: 784
I will easily admit EARTHQUAKE CUSTOMER CARE SUCKS and ther techs dont know SH!T!!! THey went and told me my PHD10000w/2 was 1 ohm stable... what happend at 1ohm? It burned the fu<k out.. and i had 2 of those amps btw they both were ran at 1ohm... until finaly i asked earthquake again why im having troubles and they told me it is 2ohm stable minimum and would not do anything about the tech that told me otherwise (i forwarded original email stating what he told me back and fourth) but i got yet ANOTHER earthwuake but this time a phd5000 and have had NOT ONE PROBLEM with it and been running it for about 3 months for hours at a time, on top of that it took me about 3 hours of steady bumping until it finnaly went into thermal protect.
Username: Redliner
Wilmington, Ma
Post Number: 3434
kicker 2500.1
