Great SQ?
Username: Qcsfinest
Charlotte, North Carolina
Post Number: 318
I need new setup suggestions to go with a kicker sx 1250.1. i was thinkin about two 13w6v2's but i want to keep my options open and keep the price down if possible. will be in a sealed box but still needs to get loud
Username: Sinful_systems70
Post Number: 194
I would get two of the Elemental designs 16Ov.2's in a 5 cu ft slot port box(2.5 per sub) (subs up ports back) with that kicker amp or a Crossfire VR1000D. Sound Quality in these subs are amazing and alot less $ than JL. Don't get me wrong, I have and like JL Audio stuff but it is quite expensive.
Username: Qcsfinest
Post Number: 319
yea ive had 12w6v2's before, im about to sell my 15" sx..... and i want good 12's. if possible black subs only
i hate shiny subs
Post Number: 198
The 13Ov.2 are just as good, just not as much surface area. I am not sure but I think you can get them in black but they are not shinny they are white. They are great subs for SQ.
Username: 04redmach1
Columbus, GA USA
Post Number: 255
SI MAG or SI BM's. DD as well.
Post Number: 204
Yes, DD = great SQL
Fi AudioBTL
Post Number: 8130
get the 2 13w6's. you won't find anything that will sound cleaner than those. they get loud too. i only got on 12w6 powered with 300wrms and it is loud in my car.
Username: Qcsfinest
Post Number: 320
yea i was thinkin i should just go with the 13w6s..... but i wanted to make sure i wasnt overlooking any subs that equal in sound quality and spl
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1570
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2900
end of search.
Fi AudioBTL
Post Number: 8141
^^^^^awesome.
Username: Steve_collins
Post Number: 262
mag
Username: Qcsfinest
Post Number: 321
thanks JP but i wouldnt have the power for two of those
Username: Gaige99
Post Number: 61
i'm sellin 2 2005 12 xxx's ; )just an idea
Username: Ars88
Post Number: 158
