New member Username: Skb1Post Number: 2 Registered: Dec-06 | Hi everyone, Great forum. Looking to add a 4 ch amp to my system in a 2004 Tahoe. Here is also what I've done so far.. H.U.: Pioneer DEH-P3800MP, Ipod in the Aux input Frnt/Rr speakers: Infinity Reference 6012SI 6.5" Deading Fr/Rr Drs:SecondSkin "Damplifier" 40sq.ft Looking for an amp in the range of $100-$150. What does any one think of Lanzar MXA412. I see it at Millionbuy.com for $95. What are some other recomendations. Also should I plan for a sub and amp later. Not really looking to set any spl records hear. Just looking for a really good family radio ![]() Let me know... Look forward to any ideas. Thanks Dean |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3757 Registered: Dec-05 | i wouldn't buy that lanzar line cuz is very overrated. Tell us how many watts do you need. |
New member Username: Skb1Post Number: 3 Registered: Dec-06 | Thats kinda of where I'm confused. The 6.5's are rated at 55 watts rms. Everyone keeps telling me to get at least 100 plus per channel? I thought to keep it close to the rated 55 watts? As to not blow them. What are your thoughts. |
New member Username: Skb1Post Number: 4 Registered: Dec-06 | Sorry heres more info 55 watts rms, 150 peak. |
Gold Member Username: James1115Use a simple... Post Number: 8200 Registered: Dec-04 | you dont want to run 150 watts to those speakers they will go POOF!!!!! I would say get a good 50x4 but your budget is very low so whatever you get in that price range is going to be highly overrated so I would look at like 80x4 or so to get 50x4 out of it. lok at this http://cgi.ebay.com/JL-audio-amplifier-300-4_W0QQitemZ110069468348QQihZ001QQcate goryZ4950QQssPageNameZWDVWQQrdZ1QQcmdZViewItem I dont know if ebay is an option for you but you can save a good amount of money on it. |
New member Username: Skb1Post Number: 5 Registered: Dec-06 | Ok, Heres what I'm thinking now. Let me know what anyone thinks of these: Orion HP-4800 4x65 @4ohms $139.00 Kenwood KAC-8452 4x60 @4ohms $149.0 Pioneer GM-6200F 4x60 @4ohms $109.0 Thanks |
New member Username: Skb1Post Number: 6 Registered: Dec-06 | Or how about this I just found.. Pioneer Premier Amplifier GM-6150F 4 Channel 600w 4X60 @ 4ohms $144.00 |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3758 Registered: Dec-05 | get the orion |
