New member Username: Superhyphy11Post Number: 8 Registered: Dec-06 | are the 1000 watt infinity subs good or bad |
Gold Member Username: James1115Use a simple... Post Number: 7857 Registered: Dec-04 | if you are reffering to the kappa perfects then yes they are nice. |
Gold Member Username: BestmankindFi AudioBTL Post Number: 7781 Registered: Oct-05 | nice sq. very nice. |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 2098 Registered: Nov-05 | for the price you can find them.. IMO they are worth it.. I've heard a few setups and they sounded clean and still got decent loud |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 3659 Registered: Dec-05 | they're very good SQ subs for the money. |
Bronze Member Username: WhitewonderPost Number: 27 Registered: Sep-06 | http://www.crutchfield.com/S-qXsctJbQHsy/cgi-bin/ProdView.asp?g=520&I=108PER121 Buy one get one free.... |
Bronze Member Username: WhitewonderPost Number: 28 Registered: Sep-06 | How do these compare to the JL 12W6V2? In the market for an SQ sub. Sorry for double post ![]() |
Silver Member Username: HomegrowncamFunky Town, TX United States Post Number: 337 Registered: Jan-05 | I would definetely put the w6 over them but they are pretty good. |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 10781 Registered: Jul-05 | w6v2 all the way.... |
