New setup idea
Username: Killer44
Ontario Canada
Post Number: 764
so im getting my suv soon and im gunna run my cvrs off my a8002t for a while till i get some money together, but im gunna set it up so i can jsut take out thatstuff and install w/eim getting so im gunna run some 0awg rite now.. iwas looking @ this kit http://cgi.ebay.ca/KICKER-PKD1-1-0-AWG-GAUGE-DUAL-AMPLIFIER-AMP-WIRING-KIT_W0QQi temZ120064080065QQihZ002QQcategoryZ79815QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
doesn neone know of enthing cheaper out there,i already got rcas and all that so that doesnt really matter but iwant the distroblocks in the kit...so im gunna run two mmats P3.0 12's ported to there specs http://mmatsproaudio.com/p30.htm
now im kinda up in the air as of what to power them with i was looking and the kx1200.1, the rockford t10001bd, and havnt really checked nething elseout...wanna keep it around 350-400 prob...but if u could help me out so i could start peicing it together i would greatly appreciate it...and ne comments on if this would be a good setup...and i got a yellowtop that i would transfer to my suv and i would be gettin a 200amp alt, big 3 ect...thanks
Username: Killer44
Ontario Canada
Post Number: 765
bump
Username: Killer44
Ontario Canada
Post Number: 767
bump...
Username: Killer44
Ontario Canada
Post Number: 768
come on...bump lol
Username: Loudon
Post Number: 691
those are good subs killer ...
as far as amps that kx1200 can be had refurbed for cheap
the sx1250 is another option if u wanted to look kicker
the wiring kit is outstanding i use it in my car works like a charm
Username: Killer44
Ontario Canada
Post Number: 770
thanx mike yeah i was leaning towards a refurbed kx... i was alos looking at the sx, jsut want to get something around 1400@1ohm and not too expensive...ne one else got ne ideas or the amp? want to stay away from hifonics and lower end "budget amps" even thou i dont want to be spending thousands on an
amp...
Username: Audiostud
Stillwater, OK USA
Post Number: 54
ed nine.1
Username: Killer44
Ontario Canada
Post Number: 771
what are those rated...i think i remember seing them listed @ 1200@1ohm?...is that right? if so would it be a better option then the kicker amps...? or does neone have ne other ideas jsut want to make sure i dont buy something right away then find something better a week later...
Username: Killer44
Ontario Canada
Post Number: 772
so all these amps ive been looking @ all say they recommend 4 awg kits, i have 4 awg rite now and was gunna upgrade to 0awg to run these amps, but now im thinking is it necessary?...should i stay with 4awg at switch out my agu fuse for an anl?...or maybe only go up to 2 awg?...will 0awg be pointless...?im only gunna be running 1400rms @ the most, depending on what amp i decide to get
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3738
also, autotek MM1400.1D
Username: Killer44
Ontario Canada
Post Number: 773
thans juliob bump for the wire size...
Username: Dsmith07
LaGrange, NC US oF A
Post Number: 319
not sure if this is what your meaning about wire size but you just get a distribution block that converts your 0 to 4 to insert in the amp
Username: Killer44
Ontario Canada
Post Number: 774
i got a distro block for 0 to 4 awg already, what i meant is that all the sites selling these amps recommend 4awg kits to power them, i was thinking i would need 0awg is it going overboard...should i go with 2 awg, stick with the awg i got and switch the agu fuse for a highr anl fuse, or jsut go with the 0awg?...
