Yellow top or Red top?????
Username: Avirex64
Vallejo, CA United States
Post Number: 192
Im gonna be pushin 2400 watts RMS and am wondering which would be better to get for under the hood. A red top or yellow top battery and which model would be good for me????? Im gonna be pushin 2 15'' Q's
Username: James1115
Use a simple...
Post Number: 7743
red top under the hood, yellow top in the back.
Username: Avirex64
Post Number: 193
so you think i should get 2 betterys??? I really only wanted to get one
Username: Seth_walker
U.S.A.
Post Number: 168
Yellow Top if you only have one.
Username: Avirex64
Post Number: 195
ok do you have a specific model I should get?
Username: Adddisorder
West palm, Florida
Post Number: 2206
get kinetikaudio.com
better batts then optima.
id get atleast the 1400
Username: Avirex64
Post Number: 198
http://cgi.ebay.com/KINETIK-HC2000-KCH2000-CAR-AUDIO-BATTERY-POWER-CELL-NEW_W0QQ itemZ120061200520QQihZ002QQcategoryZ50552QQrdZ1QQcmdZViewItem
Item number: 120061200520
Think that will do the job?
West palm, Florida
Post Number: 2209
yeah thats a nice bat. just make sure it will fit where you want it too.
also keep in mind you can turn it on its side.
Username: Extrmndor3
Im pushing i... And pushing ...
Post Number: 2845
red top, can give you around 2k crakin amps in the first 1 second so u can start u car easily, but then the amps juzz get low up to 600 amps so thats why they are goodd juzz fors starting get a red top on hood, and get two hc1400 in the back and near the amps put a hc600 and forget about dimmin im running that kind a mount in my car i have a hc600 and a red top and i still have dimming :-)
but im runnin close to 3000 rms
West palm, Florida
Post Number: 2213
you dont need a red top, even the hc600 will start a car, a yellow top will easily start a car too.
dont waste money on a red top. just get that hc2000 you found on ebay and if you still need more battery power get an hc800 in the back
Post Number: 2850
one hc2000 in the hood is not gonna make everything better except if he has at least a 290 amps alternator but at idlin he will still have dimmin wat he can do is put a hc1400 hood and a hc2000 in the back and near the amps a hc600
Username: Avirex64
Post Number: 199
so 3 batterys?????? I got a 220 amp alt and its like 120 amp at idle, so I still need 3 batts???
U.S.A.
Post Number: 169
I think you'd be fine with the hc1400 under the hood and the hc2000 in the back. if you can only get one battery now i'd make it a hc2000 and put that under the hood.
Username: James1115
Use a simple...
Post Number: 7762
I wasnt telling you to get 2 batteries I was just telling you that red top's are more for under the hood and yellow tops are more for in the car. I would go with kinetic's.
Post Number: 2853
yes u still need more batteries, i have a 180 and 120 at idle alternator on almost 3000 rms and i still have dimming with two batteries and a cap, ull need 3 batteries u can do with 2 but u still gonna have dimming not a major dimming but alil dimming.
wat u can do is get a 2400h in engine and another one in the back but it wilg et more expensive
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3640
if you believe in lilrob, you're friend of the devil hehe lol! just grab a kinetic, BIG 3 and bang your car while driving
Username: James1115
Use a simple...
Post Number: 7773
the 2400's are 75 pounds/piece. Most cars wont fit them under the hood so I would check before reccomending that.
Username: Dustin3
Tigard, OR U.S.
Post Number: 4460
i would get a yellow under the hood :-) reds and yellows are pretty similar and can both be used for under the hood, but reds have higher cranking amps, while yellows have higher reserve (more power for longer time)
Username: Avirex64
Post Number: 200
Is a kinetic like a yellow top or red top????
