Help with 1500.1zxl
Username: Sonata
hello i am going to put a 1500.1 kicker zx amp hooked up to 2 l7's in my 06 hyundai sonata and my factory alternator puts out 130 i dont know if that is idle or not but i know i will need to replace the battery it will be a kinetick i do not know which one and i only want one battery in the car just the one under the hood so can anyone advise me on which one to pick
Username: Tjmutlow
Post Number: 3319
you really should upgrade the alternator, and I hope you have the dual 2 ohm version of those subs...if not that amp is not a good matchup for the subs.
Username: Sonata
yes i do have the dual 2 ohm version and i really need to upgrade the alternator i cant just get one of the larger kinetik batteries because they give off power at a slower rate than wet cells and can get power faster than wet cells. what will happen if i do not upgrade the alterantor and stick a kinetick battery under the hood.
