Sub choices
Username: Stnorris
Davenport, IA US
Post Number: 1825
i just put that for the subject so it wasnt OT.
i just got a 200/125a alt from iraggi. i hooked it up and i wired it with big 3. when i hooked it up i did get a little antifreeze on the belts. the alternator is making squealing noises sometimes when i turn on the car, and sometimes when i pump the system up with and without touching the gas pedal. I know that the belt is tight because its a self tensioner. Does anyone know how to fix this?
Username: Logan__tille
Post Number: 2894
How long has this been going on? Or has it stopped yet?
Username: Stnorris
Davenport, IA US
Post Number: 1827
well i installed it and it did it that day, and the next day.
my lights are still dimming too? my amp is only 1500rms.
the alt is being weird...
Username: James1115
Ct
Post Number: 7502
sounds like the tensioner is not putting the right amount of pressure on the belt. Is the pulley the same size as the stock one?
Username: Adddisorder
West palm, Florida
Post Number: 2089
yeah sounds like the belt is a little loose careful or youll burn out your bearings
Username: Kyle_lowe
Post Number: 142
sounds like a fish
Username: Stnorris
Davenport, IA US
Post Number: 1830
james, the pully on the new alt is smaller. about 3/4 the size of the stock one i think.
so you think its not putting enough pressure on the belt? is that be a reason im still not gettin my voltage to stay up?
how do i fix this, if its a self tensioner?
Username: Teamdeboy1971
OPTIDRIVE LN., TN Major Bass P...
Post Number: 350
change pulleys, I have had the same trouble on alts, If its a self tensioner it needs the pulley changed, or a half inch shorter belt!
Username: Stnorris
Davenport, IA US
Post Number: 1832
ya rob that sounds pretty logical. ill have to contact iraggi tomorrow.
