Bronze Member Username: Goodie_goopMidland, Texas U.S. Post Number: 29 Registered: Oct-06 | ok im building my first box this weekend and its nothing special just a single 10" probably sealed but i dont know exactly how many screws to get or what all i should have because i have seen different things on different sites so...also maybe somewhere i can get some exact measurements to make the box... |
Gold Member Username: RovinTrinidad & T... Post Number: 9926 Registered: Jul-05 | http://www.diysubwoofers.org/ ......... ![]() |
Gold Member Username: StnorrisDavenport, IA US Post Number: 1764 Registered: Apr-06 | what sub is it? for a box you need mdf board (home depot or lowes), you need a box of wood screws, you need liquid nails, and you need caulk. |
Bronze Member Username: Goodie_goopMidland, Texas U.S. Post Number: 30 Registered: Oct-06 | its just a crappy audiobahn sub i had lying around that im gunna use till i can afford a good quality system but i guess just like a 1^ft sealed so i dont have to worry about making the port right...i shouldnt need calculations for that right? i mean just cut all sides 12"...? |
Gold Member Username: StnorrisDavenport, IA US Post Number: 1766 Registered: Apr-06 | the board is .75 thick so no. cut it like this: (2) 13.5 x 13.5 (2) 12 x 13.5 (2) 12 x 12 |
Gold Member Username: RovinTrinidad & T... Post Number: 9927 Registered: Jul-05 | Nope ! ^^^ u have 2 account 4 thickness of the wood so if u want 12" then its got 2 be 13.5" since 3/4" mdf is used another note - i read a loooong time ago u should NEVER build a box with 2 equal sides (something called "standing waves") ex : do Not use say 20 x 15 x 15 use maybe 20 x 14 x 16 http://www.the12volt.com/caraudio/boxcalcs.asp ..... ![]() |
Gold Member Username: RovinTrinidad & T... Post Number: 9928 Registered: Jul-05 | i meant "nope !" to goodie not u steven ......![]() |
Bronze Member Username: CashbyPost Number: 98 Registered: Oct-06 | i like the way that sounds rovin ^^^ good thinking |
Gold Member Username: StnorrisDavenport, IA US Post Number: 1767 Registered: Apr-06 | rovin my new box i just made had standing waves or w.e you want to call it calculated in. all boards were different. but i dont feel like drawing up a 1 cuft saeld box right now. those measurements up there should work fine though... ![]() |
Gold Member Username: RovinTrinidad & T... Post Number: 9930 Registered: Jul-05 | usually when i build boxes i try 2 design it so that 1 side is @ least a whole inch in width difference than the adjoining side well in some cases u cant help but having 2 sides almost = but i try to get @ least 1 side 1/4" different 4 this reason ...... |
Bronze Member Username: Goodie_goopMidland, Texas U.S. Post Number: 31 Registered: Oct-06 | hmmm well i kinda drew up a sketch of how it would look with measurements and i think i can do it with the: (2) 13.5 x 13.5 (2) 12 x 13.5 (2) 12 x 12 but im not sure how i could make the sides unequal...? never really done much with building this kind of stuff |
Gold Member Username: RovinTrinidad & T... Post Number: 9933 Registered: Jul-05 | thats not correct try this then 15 wide x 14 tall x 12.5 deep using 0.75" mdf enter it here http://www.the12volt.com/caraudio/boxcalcs.asp note u will get 1.07 - the .07 extra is for sub displacement ...... |
Bronze Member Username: Goodie_goopMidland, Texas U.S. Post Number: 32 Registered: Oct-06 | sweet, thanks...ill make an attempt at it tomoro and if somethin doesnt turn out right....then i guess i will b back lol |
